1999-2000 247 vs 2002+ 247? - JeepForum.com
post #1 of 15 Old 08-04-2008, 09:31 PM Thread Starter
Windowsrookie
I've been searching through 247 Transfer Cases and have a question. Why are 1999-2000 247's $700-$1,000 but 2002+ 247's are $400-$600? (Haven't seen many 2001's for some reason)
Will a 2002+ 247 work with my 2000 WJ? Will anything need to be transfered from my 247 to the new 247?
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #2 of 15 Old 08-05-2008, 05:41 AM
micifus
Original GC'er
micifus's Avatar
They use the 247 in the Quadra drive and the quadra track II maybe that is the difference between the two. There is also a 147 which is quadra track I. I am not positive but I think the quadra drive TC has a few extra parts so it works with the vari-lock. I would look for a 247 from a QD WJ.
I maybe wrong on this dont own a WJ but its a free bump at least.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #3 of 15 Old 08-05-2008, 07:00 AM
nierace
nierace's Avatar
2003 WJ
a 247 is a 247 whether its out of quadra-trac II or quadra-drive, same exact transfer case. A 2002 will work with your 2000, but the front output on the 2002 is a u-joint style yolk instead of the cv style that is on yours, so you would either need a new drive shaft or move your cv yolk onto the new transfer case (one big bolt).
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #4 of 15 Old 08-05-2008, 07:10 AM Thread Starter
Windowsrookie
So I can easily use a 2002+ Transfer case? Just have to change yolks?
1987 Wrangler 4.2L
post #5 of 15 Old 08-05-2008, 07:13 AM
nierace
nierace's Avatar
2003 WJ
Correctomundo!!!!!!!!!!!
Take the old one off while its on the jeep, or getting enough leverage to get it off is a whore
Nickerdoodle
35" BFGoodrich KM2
nierace is offline
post #6 of 15 Old 08-05-2008, 09:13 AM
moparrr07
i think somewhere around 02 they switched to the 242hd maybe ?
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #7 of 15 Old 08-05-2008, 09:28 AM
doublejz
2002-2004 they had the 242J aka 242HD but he is solo talking about the 247
04 WJ with some stuff -
doublejz is offline
post #8 of 15 Old 08-05-2008, 11:48 AM
the88thpianoman
2003 WJ
Sorry for the quick hijack, but just when I though I had TC's figured out, I read that. I thought 242HD's only came on 4.7's. I have a 242J on my 2003 4.0. Does this mean I actually have the same 242 that came on the 4.7?
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #9 of 15 Old 08-05-2008, 12:07 PM
doublejz
IIRC the 242HD which was labeled as 242J were only in the 4.7s
Edit* and it may have just been 2002-2003
doublejz is offline
post #10 of 15 Old 08-05-2008, 12:09 PM
the88thpianoman
2003 WJ
Well.... I definitely have a 4.0 with a transfer case that is definitely marked 242J. Am I special?
post #11 of 15 Old 08-05-2008, 12:14 PM
doublejz
if I'm right, that just means you have a 242 not the HD
No, not special
doublejz is offline
post #12 of 15 Old 08-05-2008, 12:18 PM
the88thpianoman
2003 WJ
No, not special
I'm confused now. If the 242HD is labeled as 242J, and my TC is labeled 242J, doesn't that mean I have the HD? Or is this one of those all of A is B but not all of B is A?
post #13 of 15 Old 08-05-2008, 12:19 PM
mendelmax
J means "Jeep" and is only a designation for what vehicle the case is made.
Therefore, all 242 are labelled 242J, the same as all 247 are 247J.
Now the thing is, that 242J for 4.0 is different than 242J for 4.7.
The 4.7 is called HD version, because it has larger chain (obviously to withstand more torque from the engine). They are not interchangeable because of number of splines.
Also keep in mind, that 247 for 4.0 won't bolt directly to 4.7 and vice versa. But having old one you can swap necessary parts.
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline
post #14 of 15 Old 08-05-2008, 12:24 PM
the88thpianoman
2003 WJ
Thank you for clarifying that. Is the spline count the only reason they are not interchangeable? Could you in theory switch splines and mount a 242HD to a 4.0?
post #15 of 15 Old 08-05-2008, 08:07 PM Thread Starter
Windowsrookie
Ok, I want to be absolutely sure before I purchase a Transfer Case. When I buy a 2002+ 247 to replace my 2000 247, all I will need to do is swap front yolks, correct?
1987 Wrangler 4.2L
Installing Electroluminescent Gauges from a 2002 WJ into a 1999 WJ jeepinitreal94 ZJ Grand Cherokee Forum 5 10-16-2012 11:02 AM
seating capacity question for the Jeeps between 1999 and 2002 27rich ZJ Grand Cherokee Forum 3 01-19-2009 01:40 AM
brake caliper recall ? 1999 - 2002 Claytonsguns WJ Grand Cherokee Forum 15 08-03-2007 11:16 AM
1999 & 2002 PCM: Any Advantages? rare-renegade ZJ Grand Cherokee Forum 4 06-06-2007 08:46 AM
Class Action Suit/DEFECTIVE ROTORS/Grand Jeep Owners 1999-2002 KevinRichard ZJ Grand Cherokee Forum 18 08-10-2004 10:44 AM
