1998 ZJ Trans Issues - JeepForum.com
post #1 of 9 Old 01-30-2014, 02:43 AM Thread Starter
ZJ98IEN
Hello everyone, new member to the forum so please bare with me. I've been having some issues with my ZJ the past couple weeks. It hasn't been shifting into overdrive. Mind you I live in Northern Wisconsin and it is freakishly cold up here this year, but I always let it warm up to temp before I take off anywhere. It wasn't until that lovely -40 f day that we had that it started doing this and the problem has persisted. I even drove 72 miles the other day without it ever going into overdrive. I didn't like it but I hadn't the option. I have replaced the trans filter with a new kit along with new fluid. No evidence of any destruction in the pan. I've checked the temp of the fluid after run time fulling expecting to burn my fingers but it was hardly even warm. What is going on here?
ZJ98IEN is offline
post #2 of 9 Old 01-30-2014, 05:19 AM
shaban
As far as I know, the computer won't let it go into overdrive when tranny oil is cold.
Quote from FSM: "The PCM prevents engagement of the converter
clutch and overdrive clutch, when fluid temperature
is below approximately 10C (50F)"
shaban is offline
post #3 of 9 Old 01-30-2014, 12:54 PM Thread Starter
ZJ98IEN
any idea as to why it wouldn't be warming up on long drives. i.e. 72 miles
ZJ98IEN is offline
post #4 of 9 Old 01-30-2014, 01:28 PM
shaban
Maybe, because its -40?
Try sticking some cardboard in front of the grille, it'll prevent the radiator running too cold and over-cooling the tranny fluid via oil cooler that's in the radiator.
shaban is offline
post #5 of 9 Old 01-30-2014, 11:53 PM
Chris_W_2k5
I had this problem before. Long drive on the highway in OD, slow down going through a city then it wouldn't go back into OD.
Definitely block the grill with cardboard or something. It'll help out keeping the engine and transmission warm. I blocked off 6 of the openings for the warm days (because here, it'll be -25*f one day and 32*f the next).
'96 stock ZJ
Originally Posted by Crashnburn80
...so assuming your Jeep is right-side-up you should be ok.
Chris_W_2k5 is offline
post #6 of 9 Old 02-02-2014, 12:19 AM
Candymancan
if its that cold.. you need to block some of the grill with something... Have you ever noticed how you see 18 wheelers on the road in the winter sometimes have like half there grills blocked off ?
Candymancan is offline
post #7 of 9 Old 02-02-2014, 12:53 AM
JasonStebbins
Besides the cold weather, check the condition and level of the transmission fluid while running warm in neutral.
Shift solenoids, governor pressure sensor, 3-4 accumulator spring, broken seal on the overdrive unit, TCC, and even a bad TPS can also cause this.
Poop
JasonStebbins is offline
post #8 of 9 Old 02-03-2014, 09:22 AM Thread Starter
ZJ98IEN
Thank you all for your suggestions. I've blocked off the grille with some cardboard, left one slot open, and so far so good!
ZJ98IEN is offline
post #9 of 9 Old 02-09-2014, 12:52 AM
Candymancan
Block off the grill where the trans lines meet in the main radiator.. assuming you use only the main radiator and your not going directly off a aux cooler like I am.
