1998 JGC stall/not starting issue - JeepForum.com
post #1 of 12 Old 01-10-2013, 06:40 PM Thread Starter
bravekate
Been going down the list, CPS is next. Just trying to narrow it down. It usually happens in warmer weather or when the engine is hotter. After replacing the TPS, complete tune-up, replacing MAP sensor, ignition coil and cleaning AIC it was working MUCH better. Didn't stall for a whole month. The weather has warmed up a bit and now it's BAD! Have heard some hints about vacuum lines and grounds but don't even know where to start. Any ideas? Recently had the fuel pump and relay replaced.
bravekate is offline
post #2 of 12 Old 01-10-2013, 07:53 PM
ZeeJay1997
Try the list in the green link below.
ZeeJay1997 is offline
post #3 of 12 Old 01-11-2013, 01:05 PM Thread Starter
bravekate
Thank you
Thank you!! Will be going down the list this weekend!
post #4 of 12 Old 01-11-2013, 05:15 PM
ZeeJay1997
Originally Posted by bravekate View Post
I've done a lot of the things on the 12-step list. Will be working on it again tomorrow. Mine is definitely worse when it's not as cold and when there is more humidity. Does that point to something in particular?
When the humidity is high it is easier for current to find a stray path to ground. When the ground path that is normally used by the current is weak, the humidity (water is a great conductor) will provide an easier path for the current, taking it into places it doesnt belong causing cross feeds across components.
So, if you havent cleaned your grounds yet, it probably should be next.
post #5 of 12 Old 01-11-2013, 06:00 PM
Bannerman53
And check all the vacuum lines for leaks. My dad's 04 WJ was acting really badly (cutting out while braking, cut-out when idle etc.) and it turns out a vacuum line was completely disconnected.
Bannerman53 is offline
post #6 of 12 Old 01-15-2013, 04:49 PM Thread Starter
bravekate
Excellent! Planned on doing it this past weekend but took longer than I thought to replace the shocks. Thanks!
BTW....been reading some of these threads for days and I gotta say, you guys crack me up! Thanks for that, too!
post #7 of 12 Old 01-15-2013, 04:52 PM Thread Starter
bravekate
Thanks Bannerman! That was also one of the top ones on the list!
post #8 of 12 Old 12-12-2014, 06:23 AM Thread Starter
bravekate
Finally fixed!!
I went down the list of 12 and got up to getting the CPS installed. Didn't fix it. But the Diesel Repair Shop next door ran some codes and finally pin-pointed the Auto Shutoff Relay. They replaced it and it's been running great for 2 days now. It had been out of commission since July 2013. Feels great to be driving it again!
post #9 of 12 Old 12-12-2014, 09:00 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
ASD is covered in the thread , coulda' saved those bucks
Originally Posted by HighLonesome
coralman is offline
post #10 of 12 Old 12-12-2014, 03:47 PM
ZeeJay1997
whatever works for you. the dirty dozen doesnt mention changing a sensor until you have determined it is bad by testing.
post #11 of 12 Old 12-13-2014, 05:05 PM Thread Starter
bravekate
My mistake
I guess I have so much information and threads and lists that I got them confused. So many others on the thread and some people I actually know in person who have had the same problem swore it was the CPS. It was inexpensive and fairly easy to do so I just did it. Actually, I had the garage next door do it because I'm not fond of tight spaces. When they were done installing it they said it had not fixed the problem. They then ran the codes and did some tests and determined that the culprit was the Auto Shutdown Relay. Popped in a new one and she's been running great for 3 days after being out of commission for almost 1 1/2 years. Luckily, this didn't cost me anything cuz they like me!
post #12 of 12 Old 12-13-2014, 06:19 PM
ZeeJay1997
no problem. if you're going to keep the jeep, it would be a good idea to bookmark the link below. it will save time, money, and questions.
not starting , stalling
