1998 Jeep Cherokee ZJ Build - JeepForum.com
post #1 of 17 Old 01-10-2013, 09:59 AM Thread Starter
Stevox84
Hey guys I am about to buy a '98 cherokee and looking to turn it into a monster. Any ideas on how much a project like this would cost?? ball park estimates? Im talking in total after 8'+ lift, steering, axles, transmission, wheels, tires, etc. etc. etc. any ideas?? thanks!
Stevox84 is offline
post #2 of 17 Old 01-10-2013, 10:06 AM
bananaslug
Many thousands.
Usual big lifts are 6 and 7 inches. Look at Clayton Offroad.
What size tire you want to run determines the lift youll need. 4.5 - 7 inches in the typical range for 35s.
Tire size also determines your axle options.
Checking Craigslist regularly for axles/tires/wheels is the cheapest route.
Id suggest looking at some build threads here for ideas:
http://www.jeepforum.com/forum/f197/
and here as well for looks you want:
http://www.jeepforum.com/forum/f13/l...-pics-1089263/
bananaslug is offline
post #3 of 17 Old 01-10-2013, 10:10 AM
WhiteOut
WhiteOut's Avatar
$15k+
Provided you do your own work.
WhiteOut is offline
post #4 of 17 Old 01-10-2013, 02:07 PM
Trick440
1994 ZJ
I like this truck... only $5k minus a few parts 2yrs ago.
http://mallcrawlin.com/forum/showthr...37-s-Long-Arms
Trick440 is offline
post #5 of 17 Old 01-10-2013, 02:18 PM
WhiteOut
WhiteOut's Avatar
Wayyy more than $5k in that Jeep considering Pat works/worked at IRO.
He also never did the axles in it. D30/44a still
Lift kit for the OP will be $3.5k alone, plus labor if he can't weld.
WhiteOut is offline
post #6 of 17 Old 01-10-2013, 04:06 PM
Crasher
Look at my sig. I have stuck about $15,000 into it after buying the ZJ. I installed the lift and all the other goodies except the gear setup. I've got about the same into the TJ. It's a lot of fun to do, but get the check book out, as everything will cost more now.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
post #7 of 17 Old 01-13-2013, 10:12 AM Thread Starter
Stevox84
Awesome thanks for te input! What kind of suspension, axle, tranny, steering upgrades would you guys recommend??
Stevox84 is offline
post #8 of 17 Old 01-13-2013, 11:34 AM
bananaslug
Clayton Offroad for suspension, works with any axles.
post #9 of 17 Old 01-13-2013, 10:55 PM
JohnnyZJ
claytons 7" long arm kit
rear 8.8 ford axle
front HPD30 both diffs with ARB air lockers and 4.88 gears
35" tires
currie steering.
tranny's fine; its a ZJ so eventually it'll crap out anyways; then you can rebuild it then.
also, if you don't have a 2WD transfer case swap in a 242 or 231.
NOT cheap; but could be fairly cool when you're done
07' JKUR rollin on 35s
JohnnyZJ is offline
post #10 of 17 Old 01-14-2013, 08:09 PM
PeteNnewburg
Which vehicle do you get your 8.8 out of? Can the ford ABS sensors be used?
PeteNnewburg is offline
post #11 of 17 Old 01-14-2013, 10:10 PM
Freestyle713
1994 ZJ
95(?)-01 explorer, and someone recently made the abs work, so its possible.
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #12 of 17 Old 01-16-2013, 12:21 PM Thread Starter
Stevox84
Why the ford axel?
Stevox84 is offline
post #13 of 17 Old 01-16-2013, 12:59 PM
SpenceAK
The 8.8 is a great axle ford is known for there rear ends. Your brake components swap right over or you can use the explorer components, most of them are 3.73 gear ratio, there's a lot of aftermarket support, theres a lot of reasons why. I'd say its the most common axle used for swaps hell I got one I'm planning on swapping in my 5.9
SpenceAK is offline
post #14 of 17 Old 01-17-2013, 06:38 AM Thread Starter
Stevox84
Awesome that sounds like a plan to me! Are those pretty expensive?
Stevox84 is offline
post #15 of 17 Old 01-17-2013, 11:11 AM
Crasher
rear 8.8 ford axle
35" tires
currie steering.
This is the basic package I have too except for the steering which I built myself and added hydraulic assist. Makes it easier to turn the 35" wheels/tires in the rocks and takes half of the load away from the steering sector shaft. Then for the overkill, I went to an Atlas tc for a lower ratio. I should knock on some wood now, but I have never broken any component after the build and the AZ rock trails are some of the toughest in the country. Build it with the best and never look back.
edit: the 8.8 from an explorer cost me $150, but I have heard some are less.
Crasher is offline
cherokee , project jeep , rock crawler , zj
