Quantcast 1998 Hesitates, chugs... - Page 2 - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1998 Hesitates, chugs...
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 02-09-2010, 01:48 PM   #16
BLACKzj52
you can check it yourself for free. run to autozone and ask them to use a fuel pressure tester in the parking lot. they should let you just use the kit. usually you have to rent it, but if you test it in their parking lot they shouldnt care.
you need 49 PSI +/- 5 I believe
- John - 22 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
Facebook
RIP Troy Edwards
BLACKzj52 is offline   Reply With Quote
Old 02-09-2010, 04:31 PM   #17
rdupuis
No Autozone here... maybe Napa? I'll check it out...
rdupuis is offline   Reply With Quote
Old 02-09-2010, 04:37 PM   #18
CoryMorgan
If it happens when you turn up your heat let me know! That's happening to mine. I've changed MANY sensors, cleaned every ground possible, new alternator, tune up, dry gas, injector cleaner, anything you can think of...
I'm out of ideas. So I run no heater Kind of sucks, especially living in upstate ny.
Let me know if you figure anything out.
CoryMorgan is offline   Reply With Quote
Old 02-09-2010, 04:39 PM   #19
BLACKzj52
napa, advanced, carquest, oriellys, try those or whatever you got near you
My Build Thead
Facebook
RIP Troy Edwards
Old 06-20-2011, 01:11 PM   #20
fotonm
After having this same problem on my 94 with a 5.2 I changed EVERYTHING that people have been talking about on here the TPS, New Tranny, New fuel filter, New fuel pressure regulator. Sometimes it would run great then other times just very sluggish and especially between about 1000 to the 2000 rpm mark. It didnt matter if it was hot or cold just very frustrating and intermittent.
Well I started to suspect a vacuum leak. While monkeying with the vacuum lines and wiggling them I got a surge and thought I was on to it. It wasn't the vacuum after all.
It was the wires that go into the TPS and when I would wiggle them it would surge and even cut off the engine. I unplugged it and Ohmed out the wires while my ohm meter was plugged into and wiggled the wires and I didnt get any Resistance drop. I figure out that the pin that comes out from the ground part of the TPS was not making a good contact with the connector. When it was not making a good solid contact I would get the problem.
You can fix this one of two ways.... you can replace the entire plug assembly to one where the female end of the connectors make a better contact or you can take up the slack in the now too loose female end with a small piece of wire inserted into the tooled out female end (lol) and now it wont be like a hotdog in a hallway and will make a good ground. Plugged it all back in and now runs like it should with full power all the way through the spectrum.
This worked for me so you may try this!! Its a connection and grounding problem not an actual prob with any of the devices.
if your grounding and connections in that TPS are not solid it spikes all up and down sending the wrong voltage to the rest of the injection system.
fotonm is offline   Reply With Quote
Glock Forum
