Quantcast 1998 Hesitates, chugs... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1998 Hesitates, chugs...
Old 02-04-2010, 11:44 AM   #1
rdupuis
My wife's 1998 Grand Cherokee LTD has started doing this hesitation/chug thing when you put your foot down on the accelerator. Seems to drive fine as you ease your speed up, but as soon as you put your foot down it kind of chgs and tries to catch up with itself. Make sense? Air filter looks good... maybe fuel filter? O2 sensor? Let me know what you guys think, thanks!
rdupuis is offline   Reply With Quote
Old 02-04-2010, 12:02 PM   #2
4Slow9erHybrid
what engine? Does this happen shortly (2-3 mins) after starting the Jeep? Then after a few more mins, problem goes away?
http://www.jeepforum.com/forum/f13/bogging-missing-957763/
1997 JGC Laredo 4.0 4x4 94000mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline   Reply With Quote
Old 02-05-2010, 02:51 AM   #3
xjhavens
Might be the tps. Same kinda thing last spring,replace and that fixed mine.
xjhavens is offline   Reply With Quote
Old 02-05-2010, 09:00 AM   #4
BLACKzj52
sounnds like fuel pump. mine did the same thing. get your fuel pressure tested. should be 49 PSI +/- 5 if I remember correctly. Anything above or below means its bad. I remember mine was at like 10psi at idle. LOL
- John - 22 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
Facebook
RIP Troy Edwards
BLACKzj52 is offline   Reply With Quote
Old 02-05-2010, 04:24 PM   #5
kmk108
If it's a 5.2, mine did the same thing. I noticed that when I put the fuel injector cleaner in the tank, It would be fine until I needed to put more in. A few months back, I needed to change the fuel pump in the ZJ, and ever since it has been changed, It hasn't happened.
30 BFG A/T, Flowmaster Super40, Alpine head unit, Alpine amp, Rockford speakers, Sony subs, cobra cb
White Jeep Club Member #108
2009 FA CUP CHAMPIONS
CAREFREE, WHEREVER WE MAY BE
WE ARE THE FAMOUS CFC
AND WE DON'T GIVE A F@#K
WHOEVER YOU MAY BE
CUZ WE ARE THE FAMOUS CFC
kmk108 is offline   Reply With Quote
Old 02-07-2010, 09:24 PM   #6
rdupuis
Okay, so I was driving it home from the hockey game today and it sputtered two big times, and then died. I had electrical still, but lost the power steering. I guided it over to the side of the road with my 4-ways and popped in neutral. I made sure it was indeed dead, and started it again. Fired right up and I drove the rest of the way home. May be coincidence, but when it happened I was turning up the heater fan to high and washing the windshield. Any ideas?
Old 02-07-2010, 09:27 PM   #7
BigRed4x4
Mine was hesistating real bad when the throttle body needed some love.
'93 ZJ, 4.0L, D30 & D35, NP231, 4" Lift, 31" BFG's, Soft 8's, Painted Cladding, Glasspack, JVC Deck, CB, Lightbars, JKS Discos & TB, Tow Hooks Everywhere...more crap.
BigRed4x4 is offline   Reply With Quote
Old 02-08-2010, 12:32 AM   #8
rdupuis
Hmmm... i wonder if it is the fuel pump. At the time it crapped out tonight, I was going up a pretty steep hill, and my fuel level is pretty low... like 1/8th of a tank. Thoughts?
Old 02-08-2010, 12:52 AM   #9
Silvin0
I drive a 1998 JGC Limited 4.0, have for almost 2 yrs experienced stalling, chugging, dogging out and backfiring to the point it blew up muffler and cat; symptoms = summer/winter, rain/sun, day/night, idling/running at hwy speeds. I've read dozens of posts and based on such random symptoms I replaced sensor after sensor. Nothing worked and I just about gave up. Finally at the prospect of possibly blowing big bucks on a new PCM I chose to start with easy/low/no cost fixes... this is what happened, I removed the three plugs to the PCM and sprayed the terminals with electrical contact cleaner and omg - it hasn't stalled in a week now. Inside the terminal housing was dirty, and it took several sprays and plugging in/out to clean them and make positive connection. Im not sure this is a universal fix, I mean consider the computer trouble codes on YOUR Jeep. I have kept up general maintenance so I think I narrowed it down after a period of time, but I hope that this helps everyone who is experiencing stall/chug/jerk/backfire.
Markus~
Silvin0 is offline   Reply With Quote
Old 02-08-2010, 12:58 AM   #10
torchd
Markus~
Where is the PCM located in the 98 Jeep (ZJ)???
torchd is online now   Reply With Quote
Old 02-08-2010, 01:16 AM   #11
rdupuis
From what I can see just by researching on this site it's behind the coolant resevoir. Please correct me if I'm wrong anyone.
Old 02-08-2010, 01:18 AM   #12
rdupuis
Markus~
I'm going to try this first thing in the morning. May as well start with the easier fixes for sure, and it's probably good maintenance practice anyway. Thanks.
Old 02-08-2010, 09:49 AM   #13
wfttalon
u could also look at a map sensor possibly. they will cause it to die an run ruff. just put one on a 5.9 at work at that took care of all his problems
wfttalon is offline   Reply With Quote
Old 02-08-2010, 09:54 AM   #14
Meanmatty
i had problems like this in one of my cars and it was just water in the tank try some dry gas before you go replacing everything
Meanmatty is offline   Reply With Quote
Old 02-09-2010, 12:42 PM   #15
rdupuis
I'll called a couple of places to check and see how much it is to have it scanned and check the fuel pressure... $90! Couldn't believe it. Found a place who would do it for $40 so guess I'll go there.
Glock Forum
