1998 grand cherokee tcm code - JeepForum.com
post #1 of 8 Old 06-02-2010, 06:11 PM Thread Starter
89cherokeeJP
i have a 98 grand cherokee 4.0 2wd i stop at a advance autoparts on the way home and it showed a tcm code and was wondering where it was located i've seen some site say it's apart of the computer on the right firewall is this correct for this year please lmk asap
1989 Cherokee 3inch RoughCounrty 31 kumho's M/T
1998 Grand cherokee Jet stage 2 chipped and aero exhuast
89cherokeeJP is offline
post #2 of 8 Old 06-02-2010, 06:29 PM
ZeeJay1997
96 and up have TCM and ECM combined in the PCM. It is behind the coolant reservoir.
What code?
ZeeJay1997 is offline
post #3 of 8 Old 06-03-2010, 01:24 AM Thread Starter
89cherokeeJP
i'll get it
but would that be causing the erratic shifting
post #4 of 8 Old 06-03-2010, 05:05 AM
ZeeJay1997
It's not common for the PCM to cause erratic shifting.
Likely a governor solenoid or TPS code.
post #5 of 8 Old 06-03-2010, 02:15 PM Thread Starter
89cherokeeJP
i went by a local junkyard today and the owner stated that the 98 models all had to have numbers matching replacements i've looked online haven't heard anything about it if fiquired if it had a 4.0 and 4sre 2wd it would work am i correct
post #6 of 8 Old 06-03-2010, 03:15 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
For a pcm? 96, 97, and 98 require different computers specific to those models. 98 also is vin programmed to the vehicle.
You don't need a pcm though. They almost never fail for the tranny controller.
ratmonkey is offline
post #7 of 8 Old 06-03-2010, 05:26 PM Thread Starter
89cherokeeJP
ok if it's not the pcm then what would cause the tcm code to throw
post #8 of 8 Old 06-03-2010, 07:20 PM
ZeeJay1997
There is no tcm or tcm code unless it's a 95 or down. AAP's code reader probably couldn't get past P0700 or P1700, which are top level codes and the parts clerk didn't know any better.
If you have a transmission related code, the PCM will code P07** or P17** on a generic scan tool. Go somewhere that has a generic scan tool, not a code reader.
I am fairly certain a 98 will NOT display MIL code with key sequencing, but if you want to try it:
(1) Cycle the ignition key On - Off - On - Off - On
within 5 seconds.
(2) After a short pause, the mileage shown on the
vehicles digital odometer will be temporarily deleted.
After this occurs, read the DTC number displayed on
the odometer. Each two–digit number will be displayed
with a slight delay between numbers.
(3) A DTC number 55 will always be the last code
to be displayed. This indicates the end of all stored
codes. After code 55 has been displayed, the odometer
will return to its normal mode.
1998 Grand Cherokee 5.9 Limited V8 Help? DWolf ZJ Grand Cherokee Forum 13 04-19-2011 08:00 PM
1998 grand Cherokee 5.9 vs 1999 Cherokee 4.7 rrich49132 ZJ Grand Cherokee Forum 89 11-27-2010 06:11 PM
ABS light on 1998 Grand Cherokee grapeman ZJ Grand Cherokee Forum 2 06-02-2009 01:33 PM
1998 Jeep Grand Cherokee for $3,000? jeepgc87 ZJ Grand Cherokee Forum 20 03-28-2009 09:46 AM
Help for a 1998 Grand Cherokee TSI lori2stj ZJ Grand Cherokee Forum 11 01-04-2009 11:06 PM
