1998 grand cherokee stereo help - JeepForum.com
post #1 of 2 Old 05-29-2015, 07:57 AM Thread Starter
Taylerhunter
I have a 98 zj limited with the infinity gold sound system, it has the factory head unit and amp with aftermarket speakers. im looking to add a line output converter to add another amp and sub. the problem is that I cant find the wiring diagram for the back of the head unit to connect the output converter to. any help is appreciated thanks.
Taylerhunter is offline
post #2 of 2 Old 05-29-2015, 01:43 PM
kg6mov
Hears the voices
kg6mov's Avatar
If you're tapping off the back of the radio this should give you the pinout for the radio itself: http://www.crutchfield.com.edgesuite.../120701817.PDF
I would tend to go aftermarket so you have better control over your sub. An aftermarket head is easy to add and retain the factory amp.
kg6mov is offline
