1998 Grand Cherokee Seat Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1998 Grand Cherokee Seat Question
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-30-2015, 12:21 PM   #1
kkspeed
The foam on the driver's seat cushion of my 98 Grand Cherokee is worn / deformed from everyday use.
Has anyone ever disassembled a Driver's and a Passenger's seat to learn if the seat cushions are the same? By seat cushion I mean the entire lower part of the seat to include the seat frame.
My plan is to dissassemble a good passenger's seat in a Junk Yard and install it on the driver's side of my GC.
I used this trick before on my 1995 Saturn.
kkspeed is offline   Reply With Quote Quick reply to this message
Unread 05-01-2015, 01:16 PM   #2
moggie99
They are slightly different shapes but are probably close enough to work.
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2003 Landrover Discovery
In the UK: 1969 MGC GT
moggie99 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2015, 08:50 AM   #3
kkspeed
Just returned from the local pick-n-pull junk yard and discovered that the lower seat frames are different so I can't unbolt a passenger's side seat cushion and bolt it in to the driver's side.
The next option is to disassemble a passenger's side seat cushion and remove the foam padding, then install it on the driver's side.
Unread 05-02-2015, 09:29 AM   #4
acmeman
Swapping the foam out should work for you.
acmeman is offline   Reply With Quote Quick reply to this message
