1998 GC 5.9 Limited: Pros & Cons - JeepForum.com
post #1 of 7 Old 06-19-2003, 09:57 PM Thread Starter
OverlandMan69
Hey all you 5.9 Ltd owners out there, i'm in the process of possibly getting a 5.9 for myself, and i just wanted all of your input. what are some pros, cons, things i should look for, advice you can give me, and what would your advice be on getting one with rather high mileage? any input on this matter is appreciated, thanks guys!
OverlandMan69 is offline
post #2 of 7 Old 06-20-2003, 02:26 AM
ViPER_SR2001
If you hear strange sounds from the back leave it! Rear axle is the biggest problem of the 5.9 and all grands.
ViPER_SR2001 is offline
post #3 of 7 Old 06-20-2003, 07:06 AM
jeepme79
Try to drive it on the highway for about 30 minutes before you buy it. When you slow down, try to make sharp turns on the pavement. If it is buckling and turning rough, you have a bad viscious coupler (see the articles about swapping a t-cases). Plan on $1500 to fix the NV249, or maybe a little less to swap to a 242 and have the 2wd option.
2003 Dodge CTD Quad Cab 4x4, 320k miles and counting
Former Jeeps:
98 ZJ Limited, 5.2L, NP242, Jet Stage II (worthless), K&N, 245/75-16 BFG KO's
89 XJ, stock
79 CJ7 - Options included ripped soft top, leaky 4.2L (5qts/week), ripped seats, 33" tires, bondo & gray primer
jeepme79 is offline
post #4 of 7 Old 06-20-2003, 08:21 AM
spichman510
spichman510's Avatar
I love mine. It has great jump off the line and great sounding stock exhaust. There is a porblem wiht the govenor and shift timing that I have i dont know if anyone else does. It cuts off power right before I shift on high rpms so it bucks but i havent heard of it much before. Overall i love mine.
Spicher
-'98 5.9 Grand Cherokee-
spichman510 is offline
post #5 of 7 Old 06-20-2003, 02:11 PM
spichman510
also anyone know the exact size of the stcok rims on 5.9 s? Ive seen 16x7 and 16x7.5 and i need a new one i destroyed mine on a sewer.
Spicher
post #6 of 7 Old 06-22-2003, 09:11 AM
Beachead19
Beachead19's Avatar
Premium only unless you want to flash the computer to run on lower octane.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #7 of 7 Old 06-22-2003, 10:11 AM
jiggajeeps
Pros: One of the fastest SUVs ever made.
Every luxury item available on the interior.
Great look, last year of ZJ body
Collectors item, one year limited production
Cons: Poor gas mileage
Must use premium fuel($)
VC can go bad
Full time 4WD
Current:
'98 TJ SE, stock
Past:
'04 KJ Sport, '98 5.9 Deep Slate, FIPK2, Mopar ECU, '93 XJ Country, '92 YJ 4.0 5speed
jiggajeeps is offline
Pros and cons 97 5.2 GC markizzy ZJ Grand Cherokee Forum 20 01-07-2009 12:28 AM
99 wj.. pros and cons island_jeeper ZJ Grand Cherokee Forum 7 12-02-2008 09:31 AM
Pros and Cons of BB bearlax4 ZJ Grand Cherokee Forum 26 05-25-2006 11:50 PM
Pros/cons of ARB WJ bumper AZ2004WJ ZJ Grand Cherokee Forum 46 05-23-2006 02:05 PM
4.0 VS V8- Pros and Cons 4XHI ZJ Grand Cherokee Forum 4 12-10-2003 12:38 PM
