1998 5.9L ZJ Bi-Xenon HID Projector Retrofit Conversion (Photos & Videos) - Page 6 - JeepForum.com
post #76 of 163 Old 01-24-2012, 06:55 PM Thread Starter
PAFirefighter11
Quadratec Live Chat Rep
PAFirefighter11's Avatar
2015 JK Wrangler
This is a 50 watt VVME, 4300K HID kit in Morimoto MH1 4.1 bi-xenon projectors. They are mounted in OE housings with lexan lenses.
The first set of photos was all taken with my Nikon D2x in manual mode. Shutter speed, ISO, f-stop, etc., are all the same. The fence is higher then the asphalt where my Jeep is sitting. The lights are at the proper height. The other photos are varying, including showing the interior LED lights activated. I still need to work on my specific aiming points (Passenger side is pointed a bit toward driver side), but this should give you an idea of what it looks like. The 50 watt kit is a bit more white/yellow-ish than my prior 35 watt kits, but there are only about 1.5 hours on them right now:
-Rick R
-2015 JKU - 3.5" JKS JSPEC Kontrol, 315/70R17" MTZ's, 17x9" Quadratec Rubicon Xtreme's, JCR bumpers & skids, JW Speaker tails, Dirty Dog netting/screens, Quadratec Auto Mirror Movers, etc
-03 VW Golf TDI - Diesel
-FDNY 9/11/01 - All gave some. Some gave all.
PAFirefighter11 is offline
post #77 of 163 Old 01-24-2012, 07:44 PM
snotrod
man that looks awesome! keep up the good work
1999 TJ, 4.0l 5sp 2" Rancho lift springs, Rancho 9000's
snotrod is offline
post #78 of 163 Old 01-25-2012, 02:04 AM
snowman65
They sure light up the road nice!.Is it possible to get a close up of the finished light to see how the seal looks?You said you used RTV sealant?How cold does it get in PA and would RTV hold up against our -40c here in Alberta?
snowman65 is offline
post #79 of 163 Old 01-25-2012, 04:08 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Being a newb to all this, I've saw you mention rotating the projector. Does this mean just loosening a lock ring or moving screws?
coralman is offline
post #80 of 163 Old 01-25-2012, 07:11 AM Thread Starter
PAFirefighter11
2015 JK Wrangler
I'll grab some shots today on my lunch of the housings up close. Here in PA it can drop as low as 0F in winter or as warm as 105F in summer. The "Ultra Black" RTV I use states:
  • Fast-curing formula that is sensor safe, has a low odor and is noncorrosive
  • Meets the performance specs of OE silicone gaskets
  • Temperature range is -65 degrees Fahrenheit to 500 degrees Fahrenheit intermittent; resists auto, shop fluids and vibration
  • Retains high flexibility, oil resistance properties through use of a patented adhesion system
I've also used the clear silicone too which states:
  • Seals, bonds, repairs, mends and secures glass, metal, plastics, fabric, vinyl, weather stripping and vinyl tops
  • Protects and repairs electrical wiring and may be applied to horizontal or vertical surfaces
  • Waterproof and flexible
  • Temperature range of -75 degrees Fahrenheit to 450 degrees Fahrenheit; resists oil, water, weather, vibration and grease
Permatex is the brand of RTV that I purchase from the local Pep Boys or Home Depot, Lowes, etc.
You can rotate the projector while it's inside the housing. There are 3 large tabs on the back. Most likely can't do it with your hands while it's mounts, I'd suggest a larger wrench. If you have not installed the housing in the Jeep you should be able to do the adjustments with your hands.
-Rick R
post #81 of 163 Old 01-25-2012, 04:40 PM Thread Starter
PAFirefighter11
2015 JK Wrangler
Finally put the cell phone down and took out my DSLR. Here are some good shots of the retro I took today:
As you can see they are dirty and still need some sanding to get the ends perfectly flat:
More shots:
-Rick R
post #82 of 163 Old 01-25-2012, 07:07 PM
WhiteOut
WhiteOut's Avatar
How much are these going for again?
Look soooo good!
WhiteOut is offline
post #83 of 163 Old 01-25-2012, 07:24 PM
somebody5788
1994 ZJ
Get some replacement turn signals and that thing will look even better.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
post #84 of 163 Old 01-25-2012, 07:29 PM
Jon20683
Looks good! Was followin your thread on hidplanet really sucks about not being able to use the fresnel lense but oh well! Is your zj stock? Any other sguff done to it
"20 year old Mass Guy"
96 ZJ Limited 5.2 Black/Gold
with some goodies
WTB=looking to by a zj I6 trans cooler-
TheSpeedFreaks.net
Jon20683 is offline
post #85 of 163 Old 01-25-2012, 07:57 PM Thread Starter
PAFirefighter11
2015 JK Wrangler
Thanks again, guys.
I have around $300-ish total of parts into the retro, plus lots of hours of trial, error and finally some success and it's still not 100% complete. Need some more sanding and such for aesthetics. I'll be selling them for a decent price for the output quality people are going to see It will definitely be worth it. Already confirmed with my buddy and we're starting to order in parts for the retros!
I'm debating some "diamond clear" signals. We'll see how that goes.
I have a K&N filter (not intake, but drop in) on order at work & custom exhaust. It's honestly all lighting really. I wheel it (See this thread: http://www.jeepforum.com/forum/f58/w...-hill-1314936/ ). It has 215,9XX miles on it, so I'm not looking into any performance mods. I enjoy my 16 MPG average on these 30's with no lift lol. If I do anything it'll be a 2" lift, and leaving the 30's.
Oh, and my buddy at work is still working on the OE lenses with some mill work. I'll post up progress photos when he finishes it.
-Rick R
post #86 of 163 Old 01-25-2012, 09:51 PM
Jon20683
You get the lenses to work ill def buy a set or buy just the lenses , as I've been dieing to do a retrofit of my own
with some goodies
TheSpeedFreaks.net
Jon20683 is offline
post #87 of 163 Old 01-26-2012, 12:06 AM
psyviperx
Looks great! Love that cutoff line. Keep us updated!
Off topic: Is that your rear O2 sensor wire dangling under there? Mine's the same way, no CEL and runs fine so i refuse to fix it. haha
04 Overland | K&N Intake | Kumho AT51
(Hers)
97 TJ Sport | D30/35 | Mods incoming...
(His)
psyviperx is offline
post #88 of 163 Old 01-26-2012, 10:36 AM Thread Starter
PAFirefighter11
2015 JK Wrangler
If I get the OE lenses to work with the milling I'd probably be able to talk my buddy into "selling" his labor for each set. If not, the only real choices are Lexan as I have done, or really crappy glass which costs $100 for a pair.
psy: Yep, it got ripped off when I crashed into that tree a while back. My MPG improved (14 to 16) when that happened, so I yet to rewire it as well My CEL comes on and then goes off every few days.
-Rick R
post #89 of 163 Old 01-26-2012, 11:50 PM
Jon20683
Fingers crossed for the milling!
with some goodies
TheSpeedFreaks.net
Jon20683 is offline
post #90 of 163 Old 01-27-2012, 07:48 AM
ExpeditionXJ
Much better than version 1... good job.
Probably missed it, but i imagine a headlight harness upgrade is a good idea as well, or do these projectors draw less?
No issues with condensation this time around?
ExpeditionXJ is offline
Projector retrofit question. 808Defender ZJ Grand Cherokee Forum 12 05-11-2011 12:32 PM
WJ Projector/HID Retrofit: Teaser Thread! UofOJeeper ZJ Grand Cherokee Forum 13 04-19-2009 05:31 PM
WJ Projector retrofit with HID's AMCMoe ZJ Grand Cherokee Forum 3 09-09-2007 07:40 AM
WJ - Nav retrofit? Z0RR0 ZJ Grand Cherokee Forum 15 12-29-2006 10:38 AM
WJ HID retrofit JCDubya ZJ Grand Cherokee Forum 19 02-19-2005 07:52 PM
