1997 ZJ Trac Bar Question - JeepForum.com
post #1 of 33 Old 01-19-2012, 12:31 PM Thread Starter
armyzj
Howdy Folks, This is my first post here, so ... Hello. Got rid of my bow-tie this weekend and picked up a 97 ZJ with a 4' Lift, sitting on 33 BFGs. Got it with the dreaded DW. My frontend was a mess, I could rotate my tie rod by hand! After getting that all under control ( Replaced : Tie rod , U joints, and upper control arm bushings). I realised my front axle was shifted about 1.5 to the drivers side. After further inspection and researching. Ive concluded that the retard PO before me should of installed and Adjustable Trac-Bar.
Anyone have any personal experience with this one ?
http://rustysoffroad.com/mm5/merchan..._Code=SUS_TRAC
Thanks.
armyzj is offline
post #2 of 33 Old 01-19-2012, 12:57 PM
badbird17x
badbird17x's Avatar
1994 ZJ
A lot of people like the iro one. Being off center won't cause dw though. Is your track bar bad? Is your caster set right? Should be around 5 degrees.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #3 of 33 Old 01-19-2012, 01:01 PM
speedbucket
Iron rock off-road.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #4 of 33 Old 01-19-2012, 01:03 PM
biebs53
These are words i love to hear
Iron rock double shear track bar
1998 Jeep Grand Cherokee 5.9 Limited
Build thread:
biebs53 is offline
post #5 of 33 Old 01-19-2012, 01:14 PM Thread Starter
armyzj
I should of said the DW was taken care of. Just have some vibrations, I'm pretty sure the tires are out of round. I just want to center the axle before i get an alignment and new tires.
I was looking at the IRO one as well. I need to get the bracket for that one, right ? Also, the write-ups I've looked at made it sound like bringing the axle back to center was wicked simple. Is this really the case ? It sounds like a PITA to me.
armyzj is offline
post #6 of 33 Old 01-19-2012, 01:20 PM
badbird17x
badbird17x's Avatar
1994 ZJ
It's wicked simple. Just have someone turn the steering wheel. As for iro having a bracket. I have no clue, I don't have one. All I know is that guys that have them, love them.
post #7 of 33 Old 01-19-2012, 01:21 PM
speedbucket
Its easy. With the tracbar removed the vehicle body will move left or right if you cut the wheel one way one way or the other. Once you have the vehicle centered properly you can just install the trackbar adjusted to the proper length. No need to muscle it around.actually. just removing the track bar and shaking the body around will bring it to center assuming your on level ground. What do you have for the back?
post #8 of 33 Old 01-19-2012, 01:22 PM
speedbucket
You only need the bracket if you get the double shear bar. They have one that will work with the factory bracket as well
post #9 of 33 Old 01-19-2012, 01:24 PM Thread Starter
armyzj
The back one appears to be stock.
armyzj is offline
post #10 of 33 Old 01-19-2012, 01:26 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Is the rear close?
post #11 of 33 Old 01-19-2012, 01:26 PM Thread Starter
armyzj
Is it worth coughing up the extra 60 bucks to the double shear with the bracket ?
armyzj is offline
post #12 of 33 Old 01-19-2012, 01:27 PM Thread Starter
armyzj
Originally Posted by badbird17x View Post
Is the rear close?
The rear is almost spot on. I'll still probally replace it, just not right now. New front bar and tires aren't cheap.
armyzj is offline
post #13 of 33 Old 01-19-2012, 01:29 PM
speedbucket
I would if I could go back in time.
You should GEt an adjustable rear as well
post #14 of 33 Old 01-19-2012, 01:29 PM
badbird17x
badbird17x's Avatar
1994 ZJ
If its good, and has you centered, I'd leave it. Hell I'd leave it anyway, but I'm a cheap ars.
post #15 of 33 Old 01-19-2012, 01:33 PM Thread Starter
armyzj
Yeah, I'm thinking a Adj rear and a trans rebuild for my tax returns. Ill try to upload some pictures of the new problem child when I get home.
armyzj is offline
axle , track bar , zj
1997 trim fit quick question Anarchist ZJ Grand Cherokee Forum 1 11-16-2011 04:15 PM
Question on a 1997 ZJ? JOES97ZJ ZJ Grand Cherokee Forum 3 09-19-2008 03:26 PM
1997 Auto Lights Question? 1997grandtazz ZJ Grand Cherokee Forum 5 06-23-2006 04:31 AM
1997 ZJ Limited with Selec-Trac? Zoso ZJ Grand Cherokee Forum 5 04-13-2006 12:03 PM
Question about aftermarket stereo in 1997 ZJ Limited maloneyx ZJ Grand Cherokee Forum 6 03-25-2005 11:42 AM
