1997 zj 5.2 - JeepForum.com
post #1 of 7 Old 06-22-2012, 08:08 PM Thread Starter
4x4jeepman777
1997 zj 5.2
for the past month my jeep has been stalling out on me. When i go to start it it will start up but will shut off second later and it will do it some times for 5 min somethings for 5 seconds. I relaced the ignition coil battery altenater and battery terminals. it seems to do it more when i put my foot in it. It will do it just driving down the road at a steady speed sometimes. I dont want to just keep throwing money at it and not fix it. any advise? thanks
4x4jeepman777 is offline
post #2 of 7 Old 06-22-2012, 09:25 PM
JasonStebbins
Sounds like the Crank Position Sensor. They are a very common failure on ZJ's. No-start issues and stalling issues.
The Throttle Position Sensor is also common to go bad. But symptoms would be sputtering/hesitation when punching the gas.
JasonStebbins is offline
post #3 of 7 Old 06-23-2012, 12:24 AM
mrclark25
1994 ZJ
could be the fuel filter. might as well replace it since it is a tune-up item.
|_|0|_|
|_|_|0|
|0|0|0|
mrclark25 is offline
post #4 of 7 Old 06-23-2012, 01:09 AM
Scopez
1994 ZJ
If I'm remembering correctly, the fuel pump and fuel filter are attached together? You supposedly should never have to replace the filter in a ZJ. Please correct me if I'm wrong though.
Back to topic, I would GUESS its the fuel pump or the Crank Position Sensor.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #5 of 7 Old 06-23-2012, 10:24 AM
sebian
If it is just shutting down, and not sputtering I would go with the crank position sensor. But before replacing it, I would test it. You can test the TPS while you have the multimeter out.
Fuel filter is part of the fuel pump on the 96-98.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #6 of 7 Old 06-23-2012, 10:26 AM
JasonStebbins
1993-1995 the filter was outside the tank. 1996-1998 the filter was inside the tank.
I wish they made fuel filters that lasted forever.
I'm still leaning towards CPS. A bad fuel pump would cause it to not start/run period. Once it went bad.
Check fuel pressure lately?
post #7 of 7 Old 06-23-2012, 05:11 PM
JeepGC8
Mine was doing a similar thing so i replaced the cps sensor and that didn't help so i changed my fuel pump and that didn't do anything so my dad decided to take out the relay and take it apart and it was all rusted and corroded so we cleaned it off and it fired right up and hasn't had a problem since. So id check the relays and that sensor then move to the filter or fuel pump
JeepGC8 is offline
ecm 1997 gc 5.2 dunegeezer ZJ Grand Cherokee Forum 0 04-06-2010 07:30 PM
1997 Zj lebaneseshowoff ZJ Grand Cherokee Forum 8 08-31-2009 11:16 PM
1997 ZJ ecm?? CumminsMan ZJ Grand Cherokee Forum 0 02-16-2009 11:51 AM
1997 ZG (yes ZG) lorrick ZJ Grand Cherokee Forum 10 03-24-2006 12:44 PM
LTB: 1997 TSi brs ZJ Grand Cherokee Forum 2 01-16-2003 03:39 PM
