1997 zj 4.0 limited key fob - JeepForum.com
post #1 of 16 Old 11-13-2013, 10:56 PM Thread Starter
spannaflicka
I all just want to sort out my door lock issue all doors lock with the fob but only the drivers un locks when pressed twice. I have a doner jeep that it all works fine my lock unlock switch will not unlock any doors either.
Questions
What do I need to swap over from doņa jeep to sort this issue
I believe the lock control module is in the pass door is this correct bear in mind I have a rhd
Cheers all
spannaflicka is offline
post #2 of 16 Old 11-14-2013, 01:57 AM Thread Starter
spannaflicka
Any help welcomed
post #3 of 16 Old 11-14-2013, 08:47 PM Thread Starter
spannaflicka
Bump
post #4 of 16 Old 11-14-2013, 09:34 PM
xcaliber81
Maybe the dealer has to enable it?
xcaliber81 is offline
post #5 of 16 Old 11-14-2013, 10:25 PM
stifmeister
Junior Member
Answer a question with a question. Post count?
stifmeister is offline
post #6 of 16 Old 11-14-2013, 10:42 PM
xcaliber81
Because im not sure sometimes its like that or there could be a problem hence the ?. I was throwing out an idea unlike you......
I know its a different vehicle but my 2008 dodge caliber is like that the dealer has to enable literally everything. Adding factory fogs dealer enabled want drls dealer enabled lane change feature (flash three times) dealer enabled ect ect.
post #7 of 16 Old 11-14-2013, 11:01 PM Thread Starter
spannaflicka
Thanks for the idea but as I said I have every thing in a doņa jeep to pull from at my Lessie
Whole car and key fob. I'm pretty sure I can grab the needed parts from that
That bit of info that I'm after is we're the door lock control that controls all doors is?
post #8 of 16 Old 11-14-2013, 11:11 PM
xcaliber81
I think its inside the passenger door takes a second to remove the pannel and check it out. Alternatively it may be stored in the pcm but not 100% sure on that do you have the fsm?
post #9 of 16 Old 11-14-2013, 11:16 PM Thread Starter
spannaflicka
Would that be the same on a RHD?
No don't have fsm were would it track that down ?
Cheers for ya help
post #10 of 16 Old 11-14-2013, 11:19 PM Thread Starter
spannaflicka
Originally Posted by spannaflicka
Would that be the same on a RHD? No don't have fsm were would it track that down ? Cheers for ya help
In in Australia btw
post #11 of 16 Old 11-14-2013, 11:21 PM
xcaliber81
Well passenger being the opposite for you lol I would imagine they made an rhd harness as well as the lhd one. Someone gave me a link to it it is free try googling it.
post #12 of 16 Old 11-15-2013, 12:44 AM Thread Starter
spannaflicka
Good to know if some one has the like post it
Will start looking shortly
Thank you hope fully will start tomorrow weather permitting
post #13 of 16 Old 11-15-2013, 12:50 AM
xcaliber81
Check your pm I sent you one.
post #14 of 16 Old 11-15-2013, 01:24 AM Thread Starter
spannaflicka
Thank you so much
post #15 of 16 Old 11-15-2013, 10:39 AM
xcaliber81
No problem man.
