-   -   1997 zj 4.0 limited key fob (http://www.jeepforum.com/forum/f13/1997-zj-4-0-limited-key-fob-1789345/)
spannaflicka 11-13-2013 10:56 PM
I all just want to sort out my door lock issue all doors lock with the fob but only the drivers un locks when pressed twice. I have a doner jeep that it all works fine my lock unlock switch will not unlock any doors either.
Questions
What do I need to swap over from doņa jeep to sort this issue
I believe the lock control module is in the pass door is this correct bear in mind I have a rhd
Cheers all
spannaflicka 11-14-2013 01:57 AM
Any help welcomed
spannaflicka 11-14-2013 08:47 PM
Bump
xcaliber81 11-14-2013 09:34 PM
Maybe the dealer has to enable it?
stifmeister 11-14-2013 10:25 PM
Answer a question with a question. Post count?
xcaliber81 11-14-2013 10:42 PM
Because im not sure sometimes its like that or there could be a problem hence the ?. I was throwing out an idea unlike you......
I know its a different vehicle but my 2008 dodge caliber is like that the dealer has to enable literally everything. Adding factory fogs dealer enabled want drls dealer enabled lane change feature (flash three times) dealer enabled ect ect.
spannaflicka 11-14-2013 11:01 PM
Thanks for the idea but as I said I have every thing in a doņa jeep to pull from at my Lessie
Whole car and key fob. I'm pretty sure I can grab the needed parts from that
That bit of info that I'm after is we're the door lock control that controls all doors is?
xcaliber81 11-14-2013 11:11 PM
I think its inside the passenger door takes a second to remove the pannel and check it out. Alternatively it may be stored in the pcm but not 100% sure on that do you have the fsm?
spannaflicka 11-14-2013 11:16 PM
Would that be the same on a RHD?
No don't have fsm were would it track that down ?
Cheers for ya help
spannaflicka 11-14-2013 11:19 PM
Originally Posted by spannaflicka
Would that be the same on a RHD? No don't have fsm were would it track that down ? Cheers for ya help
In in Australia btw
xcaliber81 11-14-2013 11:21 PM
Well passenger being the opposite for you lol I would imagine they made an rhd harness as well as the lhd one. Someone gave me a link to it it is free try googling it.
spannaflicka 11-15-2013 12:44 AM
Good to know if some one has the like post it
Will start looking shortly
Thank you hope fully will start tomorrow weather permitting
xcaliber81 11-15-2013 12:50 AM
Check your pm I sent you one.
spannaflicka 11-15-2013 01:24 AM
Thank you so much
xcaliber81 11-15-2013 10:39 AM
No problem man.
The time now is 12:45 PM.
