1997 zj 318 engine question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1997 zj 318 engine question
Jeep Grand Cherokee Mirror - Side ViewJeep Grand Cherokee Headlight AssembliesThe Retrofit Source / JW Speaker LED Headlight GROUP BUY!
Unread 08-20-2013, 04:57 PM   #1
cody024
What would cause a 318 v8 to have high oil pressure (60-70 psi) and a knocking sound. No loss of power at all, no missing and no cel. Oil is full as well. Thanks
cody024 is offline   Reply With Quote
Unread 08-20-2013, 05:17 PM   #2
dnuccio
knocking and high oil pressure dont go together. usually you have one or the other. have you hooked up a mechanical gauge to see if the oil pressure is truly that high? high oil pressure is good BTW, it means your bearings and clearances are in good shape. are you sure this "knocking" isnt just the normal mechanical noise of the engine?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline   Reply With Quote
Unread 08-20-2013, 05:20 PM   #3
cody024
I might have it hooked up to a mechanical gauge soon. The jeep sounds like a diesel lol. I can take a video with my iPhone if you'd like.
Unread 08-20-2013, 05:56 PM   #4
dnuccio
are you sure its an actual knock, and not a misfire on one or more cylinders? video would be great
R.I.P. Ratmonkey
Unread 08-21-2013, 12:40 AM   #5
LunaMoona
60-70 psi at cold idle is within specification. 60 psi at operating temperature under normal driving conditions is also within specifications.
LunaMoona is offline   Reply With Quote
Unread 08-22-2013, 03:22 PM   #6
erisbrow
1994 ZJ
You arent using Premium fuel are you?
erisbrow is offline   Reply With Quote
Unread 08-22-2013, 03:31 PM   #7
cody024
It's def a knock, and heck no lol. At 12 mpg I'm lucky I can afford 87 octane
Unread 08-22-2013, 03:33 PM   #8
WhiteOut
WhiteOut's Avatar
100% Irrelevant
WhiteOut is online now   Reply With Quote
Unread 08-22-2013, 04:12 PM   #9
zj97ltd
Just throwing out thoughts here... Would a blockage in oil passages say, near the cam bearings, boost oil pressure while starving certain components of oil?
zj97ltd is offline   Reply With Quote
Unread 08-22-2013, 05:28 PM   #10
dnuccio
i doubt a blockage would increase oil pressure
R.I.P. Ratmonkey
Unread 08-22-2013, 09:31 PM   #11
Muncie4sp
was the motor recently rebuilt?! a forgotten oil galley plug could be the issue.
1995 Jeep 5.2 4x4
2001 Ram 5.9 4x4 -sold
1996 WS6 5.7
Muncie4sp is offline   Reply With Quote
Unread 08-23-2013, 07:22 PM   #12
cody024
Motor has 84,000 miles on it. gonna have it looked at soon
