1997 Laredo 4.0L - Wiring Harnesses? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1997 Laredo 4.0L - Wiring Harnesses?
The Boss is away but Erin is here to STAY with a F.Y.S. SaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-03-2015, 12:36 PM   #1
howdyratz
Is there a place I can get wiring harnesses for the 97 4.0?
I want to replace ALL of my engine and body harnesses, because I have too many electrical gremlins and I don't trust any of my wiring at this point.
If there isn't an easy place to buy it, what's the best recommendation for testing my existing harnesses?
I'm not a big fan of the -run the engine, play with the wires- method that is often recommended here.
howdyratz is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 01:06 PM   #2
coralman
I can wish can't I?
coralman's Avatar
New harnesses, if still available are very , very expensive. Last I looked the headlight to dash harness which includes engine wiring was over a grand. With a grand and lots of time,you could fabricate your own but finding color tagged wire in every combination that mopar uses in the harness would be impossible most likely. If you developed some other method of coding wires, you pull a harness, spread it out on big sheets of plywood with all coverings off bundles and duplicate lengths, ends, ect. Other than ohm checking each wire out for continuity and checking for contact between them I know no other way than visually checking them too.
Which is the reason for.....run engine play with wires. Multiple problems often need the play with wires aspect to narrow a problem to a specific bundle,area,or connector. It is just a step.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is online now   Reply With Quote Quick reply to this message
