1997 Jeep GC Laredo will not stay running unless I give it gas. - JeepForum.com
post #1 of 5 Old 05-06-2008, 07:40 AM Thread Starter
Jubei
1997 Grand Cherokee Laredo 4.0L, has about 150k miles. Do note this problem started occuring during the first start of the day, the previous day it drove fine with no problems. Here are the symptoms, it will turn over however unless I put the pedal to the floor and hold down the gas will it start. At that point I can adjust the gas pedal to make it idle at any rpm but my foot has to remain on the pedal. The moment I take my foot off the gas it immediately goes dead. It doesnt hesitate before going dead or anything it just goes dead. I dont have a CHECK ENGINE light, nor was the vehicle giving me any symptoms prior to this happening. The only current issue that I've had prior to this was a leaking radiator that Im forced to service every other day.
I've did some research and there are quite a few things that I can see that would MAYBE cause this problem however because its not hesitating or stalling while actually driving I'm hoping I can narrow things down a bit. One thing that has come to mind is could it be a Anti-theft malfunction. Any help is appreciated thank you.
Jubei is offline
post #2 of 5 Old 05-06-2008, 11:30 AM
gearhead1186
something similair happened to my 5.2. Changed the TPS sensor and it was all gravy.
gearhead1186 is offline
post #3 of 5 Old 05-06-2008, 12:30 PM
mghutton
Could also be a IAC (Idle Air Control) motor. Its an electric motor on the throttle body that controls the engine at idle. The plunger can get clogged or stuck and not allow the air to get into the engine while at idle. I had a similar problem on mine and took it off and cleaned it with Carb and Choke cleaner and has worked fine for 4 years now.
mghutton is offline
post #4 of 5 Old 05-06-2008, 01:16 PM
gearhead1186
ditto. i actually changed both the TPS and IAC valve.
post #5 of 5 Old 05-06-2008, 01:38 PM
jonzj
Mine did that after I disconnected my battery to do some electrical work. You might have to clean the throttle body out with a toothbrush and some carb cleaner.
jonzj is offline
Jeep won't stay running unless foot is on the gas micifus ZJ Grand Cherokee Forum 31 12-22-2014 01:27 PM
Jeep wont stay running jason94 ZJ Grand Cherokee Forum 17 10-18-2013 06:42 PM
98 G/C Laredo Interior Lights Stay On Exboeman ZJ Grand Cherokee Forum 3 01-21-2009 05:24 PM
got hi centered but now the jeep wont stay running. KINGOFTHHILL ZJ Grand Cherokee Forum 15 01-07-2009 08:37 PM
my jeep won't stay running e21operator ZJ Grand Cherokee Forum 5 02-19-2007 08:40 PM
