1997 Grand Cherokee Stops Running Suddenly - JeepForum.com
post #1 of 48 Old 12-01-2009, 05:37 AM Thread Starter
hgoodwiniii
Hello everyone, my name is Herbert and I am new to the forum. I hope everyone is well. I have having a sporadic problem with my 1997 Grand Cherokee. The engine just suddenly stops at times. It happens mostly when removing my foot from the accelerator while coming to a stop. Usually, the vehicle restarts immediately without any problem. At other times, it spudders when restarted for a couple of tries. This problem is very sporadic and seems to happen about once a week and appears to happen only when the weather is cool or cold. I've had the ccm, crank sensor, tps and fuel assembly changed. Has anyone experienced this problem?
hgoodwiniii is offline
post #2 of 48 Old 12-01-2009, 06:27 AM
Sextiva
Sextiva is offline
post #3 of 48 Old 12-01-2009, 06:49 AM Thread Starter
hgoodwiniii
I may have changed it already. I'll check it out. Thanks.
post #4 of 48 Old 12-01-2009, 08:40 AM
jeepguy86
I am currently experiencing this same problem with my 97 Jeep GC. Only I have had occassions when it has taken more like 15 tries to get it to finally turn over. Had it at the mechanic but the engine never stopped when they test drove it, multiple times... only does it at random times, very strange indeed... If you find a solution that works let me know.
1997 Grand Jeep Cherokee
Red
jeepguy86 is offline
post #5 of 48 Old 12-01-2009, 09:32 AM
tkc
About a month ago, my car got really bad where the oil pressure needle would drop to zero when I came to a stop like at a light or whatever.
Turns out it was the oil pressure sensor that went bad. I was able to pick one up at the local auto parts store and replaced it. On my 1996, the sensor was located on the back side of the engine, at the top, near the center. Right between the motor and the windshield.
Just a thought, incase your oil pressure needle was dropping when this happens.
Good luck!
tkc is offline
post #6 of 48 Old 12-01-2009, 04:00 PM
ZeeJay1997
Welcome Herbert
Try gently wiggling the PCM connectors and tapping on the PCM while the engine is cold.
Also try swapping the fuel pump relay and the ASD relay with the horn or int wiper relay.
Also see this thread post 22
http://www.jeepforum.com/forum/f13/s...s-help-859227/
ZeeJay1997 is offline
post #7 of 48 Old 12-01-2009, 04:11 PM
Az-Green
1994 ZJ
My ZJ just took a **** on me a few days ago and the problems were very similar to this. Have you had your fuel pump checked out? Mine was toast. It's replaced and runs like a monster again.
Az-Green is offline
post #8 of 48 Old 12-01-2009, 04:14 PM
Sextiva
You could prolly test the ASD and Fuel when it happens. Just see if the pump is priming.
Sextiva is offline
post #9 of 48 Old 12-01-2009, 05:16 PM Thread Starter
hgoodwiniii
Will do. Thanks for all the suggestions. By the way, what's the ASD?
post #10 of 48 Old 12-01-2009, 05:47 PM
Sextiva
Its a relay that kills spark and fuel to keep from damaging your vehicle. It will feel like someone reached over and turn your key off if its engaged. Chrysler likes to use em.
Sextiva is offline
post #11 of 48 Old 12-01-2009, 05:59 PM
Curly5759
You have that backwards. The ASD (Auto Shut Down) relay is used to provide power to the ignition, fuel pump and injectors.
It receives 12 volts from the ignition switch and ground from the computer. The computer will turn the relay off (remove the ground) if the RPM signal from the Crankshaft sensor disappears or is not present.
Curly
Curly5759 is online now
post #12 of 48 Old 12-01-2009, 06:02 PM
BLACKzj52
welcome to the forum
dont forget to check for some vacuum leaks around the intake manifold. you can do this by taking throttle body/carb cleaner and spraying it around the hoses that connect to the sides of the manifold. if the idle increases you have a vacuum leak at the area you just sprayed.
BLACKzj52 is offline
post #13 of 48 Old 12-01-2009, 06:15 PM
ZJ5point2GCL
my vote is the IAC especially if its when you take your foot off of it
ZJ5point2GCL is offline
post #14 of 48 Old 12-01-2009, 06:32 PM
Sextiva
Curly
Pretty sure like in the old 2.2 turbos, if you hooked a boost controller up and cranked up the boost. The MAP would see the increase in manifold pressure, and say oops overboosting, and cut spark and fuel. Could be wrong tho
Sextiva is offline
post #15 of 48 Old 12-01-2009, 06:59 PM
ZJJay
ZJJay's Avatar
I've had similar problems in the past two years. First time the shop found a bad ground on the Auto Shut Down relay. Worked fine for a few months, then started acting up again. Actually it was running fine, then wouldn't start. The crankshaft position sensor had failed, which is a common problem. Recently I had a wildly fluctuating idle at start up. I changed the Idle Air Control valve and fixed that problem. When replacing the IAC valve, be sure to clean out the area inside the throttle body. I didn't want to spray carb cleaner in there, just to wash all of that carbon and gunk down into the passages. I dipped Q-tips in paint thinner to clean it out. Works fine now. I hope this helps.
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline
Grand Cherokee suddenly making a nasty 'rattle' Spanishfly ZJ Grand Cherokee Forum 5 02-01-2010 11:32 AM
2008 Grand Cherokee Died suddenly JohnDeerCJ WK Grand Cherokee & XK Commander Forum 6 07-08-2009 06:19 PM
Need Help getting 1997 Grand Cherokee Running drds144 ZJ Grand Cherokee Forum 7 05-04-2009 09:41 AM
Jeep suddenly stops once I get to about 18 mph bonnie_michelle ZJ Grand Cherokee Forum 10 06-05-2007 10:25 AM
Smoking suddenly - 94 Grand Cherokee gradejohn ZJ Grand Cherokee Forum 7 10-19-2006 11:00 AM
