1997 Grand Cherokee Laradeo, stalls after cold starts. - JeepForum.com
post #1 of 15 Old 09-05-2007, 09:59 AM Thread Starter
MRCLIVE
1989 MJ Comanche
Hello everyone,
I am new to Jeep Forum. I have the following problem, my 1997 Grand Cherokee Laradeo ZJ inline 6 4.0L stalls out after a cold start. If i warm it up for about 20 minutes it seem to work just fine. However, lately as the temperatures have been in the low 60s and 50s at night and in early mornings the problem has gotten worst. It seems to work fine when temperatures above 70 degrees. After searching the forum and following all the good advice the problem persists.
Here is a list of my action to date. I have replaced the wires, plugs, distributor w/cam sensor, cap & rotor. Ignition coil, TPS, Idle Air Control valve. I have a new catalyst converter. Repaired an exhaust manifold leak (new manifold). Inspected the battery cables (ok), applied dielectric grease to most electrical connection with exception to connections on throttle body.
Once again, after getting hot it runs fine. It only after cold starts when temp is below 70 degrees I have problems. In fact just this morning temp was about 62, started it up, warmed up, and drove about 1 or miles it stalled. I was able to restart and continue. Now that its hotter it will start up and go without issue.
Any thoughts on what else my problem could be. Thanks in Advance.
MRCLIVE is offline
post #2 of 15 Old 09-05-2007, 11:55 AM
impuresoul2k3
Sounds like it's running lean. Test out the coolant temp sensor. I have mine rigged up so mine thinks the jeep is 247* (to help lean it out and get better gas mileage) and I have to turn the switch off to get it to start and if I turn the switch back on it will hesitate or stall out depending on the load, next time you start it try tapping the peddle until you get the rpms around 1500 then you can drive it like normal. You may have to drive like that for a few minutes until it warms up.
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #3 of 15 Old 09-06-2007, 09:51 AM Thread Starter
MRCLIVE
1989 MJ Comanche
Thanks for tip.
I tested the coolant temperature sensor. it appears to working fine. I unplugged it and started the engine, it immediately stalled and check engine light came on. Reconnected, started it and it stalled several minute later, but without check engine light coming on. After another restart it ran
after reaching operating temp of 210*. Still searching for a fix.
Thanks again.
MRCLIVE is offline
post #4 of 15 Old 09-06-2007, 11:12 AM
rm2001wj
rm2001wj's Avatar
Check to see if there are any trouble codes, not all codes turn on the CEL.
Use the DIY method in this link: http://www.zjilla.com/tech_codes.htm.
Or, go to someplace like AutoZone and get them to connect a code reader. They do it for free.
Let us know what the result is.
rm2001wj is offline
post #5 of 15 Old 04-21-2009, 04:01 PM Thread Starter
MRCLIVE
1989 MJ Comanche
Update to stalling issues. Finally found the cause of the intermitten stalling. After selling the Vehicle. It turn out that the three connectors that plug into the PCM were broken. By being broken they were not staying in place. So once the ZJ went over a bump they dislodged. Apparent on the restart the current draw pulled them back in. So after buying repair kits for the plugs. The Jeep is running fine.
MRCLIVE is offline
post #6 of 15 Old 04-25-2010, 11:36 AM Thread Starter
MRCLIVE
1989 MJ Comanche
Turns out the last post was not correct. The vehicle has been returned. The fixed was the ignition coil replacement. '97 Grand currently on the road and running good.
Just might be the problem for others as well. Oh and by the way its been running without issue for at least five months.
MRCLIVE is offline
post #7 of 15 Old 08-08-2010, 07:28 PM Thread Starter
MRCLIVE
1989 MJ Comanche
'97 Grand Cherokee Laradeo still running after ignition coil replacements. In fact just put on four new tires. See earlier post, if you are experiencing similar issues give it a try and post your results.
MRCLIVE is offline
post #8 of 15 Old 11-12-2013, 05:04 PM
NissanGuy23
Im having issues with stalling only in cold weather, 10-20 min after startup. So, if its 50 DEG plus outside, it has never stalled. If its freezing cold, but the Jeep has been given 20+ min to warm up, it has never stalled. It only stalls in a situation where the Jeep has been sitting for 9+ hours, and its 34 DEG outside, when you fire it up, it will stall and die multiple times until about 20 min in it starts to run normally.
Things replaced to far (not necessarily to stalling but for other reasons): CPS, Harmonic Balancer, Alternator, Serp Belt, Cleaned the IAC, new cat-back exhaust.
The car is a 1996 Jeep GC Laredo 4.0 Auto with 227,000 miles.
So do you think its the ignition coil? The next thing i was going to try was cleaning the throttle body. Any help very appreciated, tired of stalling on the way to work
NissanGuy23 is offline
post #9 of 15 Old 11-13-2013, 06:06 AM
ZeeJay1997
wiggle pcm connectors while cold. see link in my sig
ZeeJay1997 is offline
post #10 of 15 Old 11-13-2013, 09:53 AM
NissanGuy23
My PCM came zip-tied from the previous owner. If the PCM stall issues can be linked to cold weather, pre warm up, than ill target the PCM as a possible cause and try to clean, ect. People keep giving different recommendations, not sure which to look at.
post #11 of 15 Old 11-13-2013, 11:31 AM
Oldfrog
2007 WK
That's usually a dead giveaway that the PCM is bad. Not always...but most of the time.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #12 of 15 Old 11-13-2013, 04:46 PM
NissanGuy23
Check out this video i took, car has been sitting in pretty cold weather for 24 hrs. Did its usual hard to start up / stall. Died when i put pressure on the third connector, so i guess ill get learning how to reflow a PCM pretty soon.
post #13 of 15 Old 11-13-2013, 09:16 PM
JS97ZJ
My Jeep was doing the same as in the video. (touch the PCM plugs and loose power)
After spending much time on that problem with others on this forum, I came up with the solution for the loose connections that worked on mine.
http://www.jeepforum.com/forum/f13/9...tures-1303589/
It solved my situation and care must be taken when doing it. But you should first go through ZeeJay's 12 things list (the link in his signature in his post above) before you tear the PCM apart.
Another member found it was the pins that were making intermittent connections due to sloppy openings in the harness connectors.
JS97ZJ is offline
post #14 of 15 Old 12-16-2013, 07:04 AM
rpm0627
what is a pcm I am having the same issues with my jeep in the morning its stalling when I make a complete stop or ak idiling for a while
rpm0627 is offline
post #15 of 15 Old 05-12-2017, 09:48 AM
allynnc
My ZJ (262,000) starts instantly, idles rough, but drives away just fine. Within 3-10 blocks it will just stumble and die particularly at a stop sign or light. Sometimes if I put it in neutral and pump the gas pedal it will continue to run. When it is above 70 degrees it seldom dies. It usually restarts immediately, but a few times I have had to pump the gas pedal while restarting. Once it has done this once for the day, I can drive for hours without further problems for the day with a smooth idle and no driving problems. It says coolant sensor bad so I have replaced both the coolant sensor and the intake air temperature sensor and still get the message. Once it has warmed up the message is still there, but temperature gauge shows 210 and it is running great. My oil pressure is 38 at idle and 49 at rpm cold or hot. Once temp gauge is at 210 it has only stalled one time in the last year and it was near freezing outside and driving a very low rpm for a long time. It acts like it is starved for fuel like a carb choke opening too soon. If I have enough rpm when it starts to stall, I can sometimes put it in neutral, pump the gas a few times and not stall that day. I seldom floor the gas, but it does not starve when floored so fuel pump is fine.
allynnc is offline
1997 Grand Cherokee 4.0 Random Stalls hawaii50 ZJ Grand Cherokee Forum 42 06-09-2013 08:43 AM
Jeep starts,revs up and then stalls (once warmed up, cold it stays running). Coletrickle ZJ Grand Cherokee Forum 11 03-18-2009 08:53 AM
98 Grand Cherokee goes 150' then stalls. superubicon ZJ Grand Cherokee Forum 0 04-07-2008 07:14 AM
94 grand cherokee starts then stalls. please help!! -darren- ZJ Grand Cherokee Forum 4 07-24-2006 09:57 PM
99 Grand cherokee stalls. bkbs22 ZJ Grand Cherokee Forum 2 02-01-2006 03:17 PM
