1997 Grand Cherokee air conditioning problem - JeepForum.com
post #1 of 3 Old 08-07-2002, 05:14 PM Thread Starter
bootown
I have a 97 jeep grand cherokee. the problem is that the air conditioning drain is no longer working properly. water has leaked out onto my feet while driving and another time has soaked the rear passenger side floor with water (a lot of water). I need help finding where the air conditioning drains through. thank you very much for any advice you can offer.
greg
bootown is offline
post #2 of 3 Old 08-08-2002, 08:07 AM
ptcpa
same problem
I have a posting on the forum titled "condensation on floorboard....help!" with the exact same problem. A gentlemen was kind enough to share this info with me:
"if you look under the dash, behind the carpet on the passenger side, there is a black plastic piece. drill a 1/4" hole in the middle of it. then take a coat hanger (or whatever), and poke it around in there. to plug it back up there is a plug you can buy from the stealership or you can just cover it with black electrical tape, like i did.
if you need more info, do a search at www.jeepsunlimited.com or www.nagca.com . i saw a write up about it at 1 of those sights."
I checked out the sites and he is correct, many people have fixed it this way. You can also use black RTV sealant to reseal the hole. Just an FYI......
1996 Grand Cherokee Limited 4x4
Fully Loaded, Black, 5.2L V8
K&N with 'high-flow' exhaust....sounds better than a 5.9
ptcpa is offline
post #3 of 3 Old 08-08-2002, 08:13 AM
ptcpa
forgot to add
Sorry, forgot to add........if you are able to fix your's relatively quickly or hear of any other way to fixe it please let me know exactly what you did. I'm planning to work on ours this weekend and the more one knows the better.
ptcpa is offline
1997 Grand Cherokee Fuel Pump Problem james_tessier ZJ Grand Cherokee Forum 8 11-28-2009 02:33 PM
1997 Jeep Grand Cherokee- electrical problem? Mikeyp-97 ZJ Grand Cherokee Forum 0 08-23-2007 07:44 PM
1997 Grand Cherokee Serpentine Belt Adjustment Problem Den46 ZJ Grand Cherokee Forum 2 11-04-2005 10:35 PM
Air Conditioning Trouble 2004 Jeep Grand Cherokee Loredo tgwem2 ZJ Grand Cherokee Forum 8 06-21-2005 05:35 PM
1997 Grand Cherokee No Start Alarm Problem? Andrewiski ZJ Grand Cherokee Forum 0 03-08-2004 10:12 PM
