1997 Grand Cherokee - JeepForum.com
post #1 of 9 Old 08-21-2007, 05:57 PM Thread Starter
Deadbolt
1997 Grand Cherokee
My son has a 97 GC Orvis 5.2L V8. It frequently hesitates for a second or two when accelerating from a dead stop - like it's choking. I doesn't do this all the time, just occasionally, and it seems to happen more often when the gas level is at 1/4 tank or less. It does not create any computer codes. We've changed the fuel filter, had the injectors cleaned, gas tank removed and cleaned, replaced the fuel pump, and checked the fuel pressure. Our mechanic now believes the fan clutch may be the cause, wherein the gas is getting too hot and not flowing smoothly through the injectors when you accelerate. I've also been told by someone else to check the TPS (throttle position sensor). So far, this has all been guesswork. If anyone has any specific ideas that would help narrow down the cause, I'd sure appreciate it.
Deadbolt is offline
post #2 of 9 Old 08-21-2007, 06:36 PM
Reswob
Do you only notice this when turning from a stop, or all the time?
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #3 of 9 Old 08-21-2007, 07:58 PM Thread Starter
Deadbolt
He says it's mostly when making a turn from a stop, but sometimes also when going straight ahead.
Deadbolt is offline
post #4 of 9 Old 08-21-2007, 08:23 PM
Country Jeep
Comanche Kemosabe
Country Jeep's Avatar
I recommend that you don't go any farther without replacing the TPS; it sounds like that's the problem. It's not that expensive ($40), and can be installed in 5 minutes. It isn't worthwhile to go through the whole voltage-checking process to see if it's bad, I would recommend that you just go ahead and replace it. They usually go bad every year or so (at least, in my case), and can cause all sorts of acceleration- and shift-related problems.
Main rig under screen-name...
, 4.0L HO I6, AW4. Daily driver.
'98 XJ Classic (moss green) 2WD, 4.0L HO I6, AW4. Restoration project.
Gone, but not forgotten:
, '94 ZJ Limited, '85 CJ7,
Blue Jeep Club Member #113
Country Jeep is offline
post #5 of 9 Old 08-21-2007, 08:55 PM Thread Starter
Deadbolt
You're the second person that has suggested the TPS, so that's what we'll do. I appreciate your input. Do you have any thoughts about the mechanic's suspicion involving the fan clutch?
Deadbolt is offline
post #6 of 9 Old 08-22-2007, 10:09 PM
Country Jeep
Comanche Kemosabe
Very far-fetched. If the fan clutch was bad, either the motor temperature would rise to dangerous levels because the clutch is not engaging when hot, or the motor would never warm up because the clutch is stuck engaged.
What is the average engine temp. when driving and stopped? Have him read the temperature gauge after it's warmed up, and has been sitting for at least 5 minutes idling.
Another note, if the clutch was stuck engaged, the fan would be extremely loud when revving up the motor. Some people complain about the fan being loud when taking off from a stand-still when the motor is still cool. This is normal, but if the fan seems loud all the time, every time the motor is above 750rpms, that could be an indication that the clutch is stuck.
Again, I highly doubt that that's the problem, or that such a problem would effect the fuel system, but it is still something to look into. You never know...
post #7 of 9 Old 08-22-2007, 10:24 PM
ezrider327
Go to a different mechanic I've seen stranger things happen but the fan clutch was on the last of the list, wait actually it wasn't on the list at all for this one.
X3 for a TPS and see if it cures it.
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!! ESSAYONS
97 F350 Dually CC Powerstroke- - 65 Mustang - 74 Super Beetle - 93 Harley Sportster
97 ZJ 4.0 4x4 Auto : Rusty's BB lift & Rusty's K&N intake
235 75 15 Toyo Open Contry AT's 15x8.5 Eagle alloy's
Flowmaster exhaust, custom winch bumper, Ramsey 9000lb, THULE MOAB roof rack
ezrider327 is offline
post #8 of 9 Old 08-23-2007, 11:39 AM Thread Starter
Deadbolt
I appreciate the response. Looks like the majority think the TPS is the likely cause, so that's what we'll do. I wasn't really convinced about the fan clutch anyway. Just didn't seem logical to me. But, if the TPS doesn't solve the problem, then I guess we'll try it. Thanks to everyone who responded to my question.
Deadbolt is offline
post #9 of 9 Old 08-23-2007, 01:06 PM
alivenkickin28
yeah and has he changed his spark plugs ? If they're original i'd change those too -- mine ran better after that - it kinda hesitated a lil before i had them changed -
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
1997 grand cherokee jboidock ZJ Grand Cherokee Forum 4 09-02-2009 10:10 PM
1997 Grand Cherokee 150$ stevejg ZJ Grand Cherokee Forum 10 03-02-2009 06:52 PM
1997 Grand Cherokee YJMCBoy ZJ Grand Cherokee Forum 11 01-24-2009 07:08 PM
1997 Grand Cherokee CBlakeNS ZJ Grand Cherokee Forum 1 06-24-2007 10:14 PM
1997 Grand Cherokee A/C HELP! mac6135 ZJ Grand Cherokee Forum 3 07-14-2005 01:59 PM
