1997 5.2 crank but no start, need help with crank sensor replacement.
#1 | |
hey guys its my first time posting on here and i need some advice
my jeep just died while driving the other day and doesnt have any spark and the coil has tested good. i can hear the fuel pump turning on and gas in the intake doesnt make it start. my auto teacher told me ot replace the crank sensor as it is the likely problem but after looking at the location..... im in ohio currently working on a gravel parking lot covered in snow, i have jack stands i can use but its freaking cold, any way to get at it from through the shifter? and any other stuff i can do to be sure this sensor is the problem?
#2 |
oh and if anyone knows the correct size of the 2 bolts it would save me some headaches out in the cold.....
#3 |
Captain Awesome
pull codes before purchasing parts. It may not be a crank sensor.
#4 |
i dont have easy access to a scanner but there is no check engine light on.
#5 |
if there is no CEL light it could be the CPS or the ECM. I believe that when we did ours the bolts were 8mm.
![]() - HM1(SW/AW) USN 1992 to present I drive an XJ, and all of my power windows work :) DD (Mine) - 98 XJ Moss Green (His) - 92 YJ Sold - 95 ZJ Sold - 97 XJ Red Sold - 98 XJ USN Jeep Club Hull #36 NAXJA #3700 |
#6 |
8mm? they seem bigger than that but im not sure. im going to have to get a ratchet flax head wrench i think so i would like to be sure on the size if possible
#7 |
Life is a dick.
Mine were 1/4" allen wrench, but mines a 94.
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 32x11.50r15 Dunlop Mud Rovers, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion In the works: HP30 build. WJ knuckles, crossover steering, lunchbox locker, extras. BUILD THREAD:http://www.jeepforum.com/forum/f197/its-name-black-jeep-1133312/ R.I.P Debora Ann Greer. 10/19/59-08/31/11 I love you, and miss you mom, you were the one who got me in to jeeps, and taught me to live my life. I'll never forget everything you taught me. |
#8 |
If you haven't fixed it already, it may be the IAT sensor on the throttle body.
#9 |
You can also you a hex bolt to access mine, 98 5.2 v8. Makes it a lot easier.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
