1996 ZJ No shift - JeepForum.com
post #1 of 10 Old 03-12-2011, 02:08 PM Thread Starter
lilkinz17
1996 ZJ No shift
Hey, I'm new here and need some help. Have the 96 ZJ grand with 4.0L I6 and 42RE. Had problems with shifting. in Drive its in 3rd all the time, can shift down to 2nd manually and shift back up manually but won't shift into 1st or OD. pulled code p0748 which was the Governor Pressure Solenoide, so i put in a new solenoid and sensor. Nothing changed. Need ideas. Please help me out.
LilKinz17
lilkinz17 is offline
post #2 of 10 Old 03-12-2011, 03:32 PM
larudy
check the transmission fluid levels or o2 sensor i had an issue like youts ended up being o2 sensor
i love my piece of crap jeep :)
larudy is offline
post #3 of 10 Old 03-12-2011, 03:36 PM
larudy
oh and btw i was getting a check engine light too for governor sensor when i had just put on a new trans so i found out when the o2 sensor is bad it can give a funky reading but it does really cause loss of rpms hence the transmission having issues shifting when it should. oh and btw did you change the tranny fluid because thats what cause my first tranny to blow..long story short hose collapsed 2am on the highway and all tranny fluid leaked out then my mechanic put new fluid blew the trans then bought new one then had shifting issues due to o2 sensor
larudy is offline
post #4 of 10 Old 03-12-2011, 05:08 PM
neonhomer
Make sure you cleared the codes after replacing the solenoid. Also replace the pressure sensor at the same time.
When you tranny starts out in 3rd gear it means it is in Limp Home mode.
Weird about the O2 sensor....
neonhomer is offline
post #5 of 10 Old 03-13-2011, 04:29 PM Thread Starter
lilkinz17
had a tranny put in so the fluid and filter is brand new. im starting to think theres a wire problem between the pcm and tranny so thats where im goint to look
post #6 of 10 Old 03-13-2011, 05:40 PM
ZombieJeep93
is this a new trans or a reman? has it been doing this since trans install? is there still any warranty on trans?
could be bad wirng pcm to trans or in trans from connector to gov sol and sensor. could also be valve body problem.
just a few things to consider.
93 Grand Wagoneer (de-wooded) 5.2 Mag, 2"BB, Magnaflo Cat, Gibson ex, K&N CAI, Mopar pcm, 32" BFG AT, Accel truck ignition
ZombieJeep93 is offline
post #7 of 10 Old 03-14-2011, 08:27 PM Thread Starter
lilkinz17
reman tranny. starting acting up with the old one so i had the reman one installed. still nothing so i installed a sensor and solenoid and inspected the valve body as well. all is good so i turn to electrical. im thinking a bad wire from pcm to tranny connector. i need to get ahold of a multimeter and run an ohm test to make sure
post #8 of 10 Old 03-14-2011, 09:58 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Codes?
ratmonkey is offline
post #9 of 10 Old 03-17-2011, 10:29 AM Thread Starter
lilkinz17
only code i get is p0748 which is the pressure solenoid circuit.
post #10 of 10 Old 11-05-2013, 04:31 PM
Procide
Did you ever figure this out? I'm in the EXACT same situation. I replaced my transmission and govenor pressure solenoid as well. I tested my wiring and everything checked out. The solenoid to PCM was putting out voltage under load as well so the only thing left seems to be a bad PCM.. Let me know!
2003 Wrangler TJ 2.4 Soon to be turbo
1998 Grand Cherokee~7" Long arms on 35s
2008 BMW 335xi
Procide is offline
cherokee , grand , shifting problem , transmission , zj
1996 zj diesel04 ZJ Grand Cherokee Forum 5 03-10-2011 07:05 PM
1996 4.0 GC Laredo wont shift into 4th gear dannye1987 ZJ Grand Cherokee Forum 1 08-30-2009 09:54 PM
1996 zj erratic shift from 1st to 2nd mdav8629 ZJ Grand Cherokee Forum 0 11-08-2008 06:55 PM
Does this go with a 1996 ZJ? whitejeep08 ZJ Grand Cherokee Forum 8 12-24-2006 02:06 PM
1996 v8 vs. I6 Zack2047 ZJ Grand Cherokee Forum 17 10-30-2003 08:32 AM
