1996. ZJ Limited V8 clutch problem? - JeepForum.com
post #1 of 6 Old 06-20-2011, 12:20 PM Thread Starter
zaczg
Hi guys,
I live in Zagreb, Croatia, so I dont have a lot of friends who drive Jeep Grand Cherokee, so please help me
Well, the problem is very simple, I dont have experience with automatic transmission, and my Jeep 5.2 V8 does have automatic transmition, but this is the problem:
When I have to start moving (press the pedal in D - drive mood), sometimes (not always), the front of the car shakes very nasty and it seems like it has a problem to shift gear.
It doesent happen very often, and this shows sometimes also when I am driving about 40-50 km/h and press the pedal (power) and RPM goes but not speed , if you understand me .
It is like you have a lazy clutch on manual transmition.
So, please what could be the problem so I can find parts and replace it.
Thank you!
zaczg is offline
post #2 of 6 Old 06-27-2011, 10:43 AM Thread Starter
zaczg
anyone? pls help
zaczg is offline
post #3 of 6 Old 06-27-2011, 11:07 AM
Midnightluckey
Are you saying like it's slipping in gear? When you push the gas, it revs but the transmission doesn't engage?
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #4 of 6 Old 06-27-2011, 12:56 PM
corndogduff
It sounds like you have a slipping transmission. You can look into the writeups about transmission band adjustments, which aren't TOO hard, or take it to a transmission shop and have them rebuild it and install a shift kit which is DEFINITELY worth your time/money if you can find someone to do it right.
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #5 of 6 Old 06-28-2011, 12:35 AM Thread Starter
zaczg
Yeah it sounds bad like some metal is comming and revs go up but car dont, and it is sometimes when I push the gas pedal to the ground fast. When I drive normal it never shows.
2corndogduff transmission band adjustment? what is that?
This is my first automatic transmission car, so I dont know how it works exactly.
Thanks guys!
old miata driver new Jeep owner
owns a stock Jepp Grand Cherokee Limited 5.2 V8
zaczg is offline
post #6 of 6 Old 06-28-2011, 10:11 AM
corndogduff
Totally cliche, but this should give you a good primer on auto transmissions.
http://en.wikipedia.org/wiki/Automatic_transmission
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
1996 limited popping/ticking Green01XJ ZJ Grand Cherokee Forum 3 03-29-2011 07:34 PM
1996 ZJ 5.2 4wd Limited Need advice dropped74 ZJ Grand Cherokee Forum 1 07-04-2010 03:52 AM
1996 GC Limited V8 EvilMonkey ZJ Grand Cherokee Forum 2 05-28-2009 06:35 PM
1996 Limited VIC john96zj ZJ Grand Cherokee Forum 8 01-12-2009 12:27 PM
1996 Grand Cherokee Limited Paris Holley ZJ Grand Cherokee Forum 6 06-12-2005 07:50 PM
