1996 zj lift question - JeepForum.com
post #1 of 35 Old 09-19-2011, 04:27 PM Thread Starter
1993redjeepyj
Hello all.
just ZJ back and im looking to continue my build.
just one question, how much lift can i go with stock arms?
these 1000 dollar kits are just way out of my budget at this time.
im looking at the rustys off-road 3 inch kit right now. any suggestions?
from what i gathered 3 inch is the biggest i can go with stock arms
but i was looking to lift 4 inches. but if 3 is the biggest i can go then i will deal with 3 inches
thanks in advanced,
Steve
1993 Red jeep wrangler YJ, 2.5L-----SOLD
1997 Blue ford f150, 5.4L----SOLD
1996 Jeep Grand Cherokee 5.2L V8------SOLD
1991 GMC Seirra 5.7L----Project truck
2010 Hyundia Accent BLUE------Current DD
1993redjeepyj is offline
post #2 of 35 Old 09-19-2011, 04:43 PM
PolkaPower
Upcountry coils 1" and a 2" BB.
PolkaPower is online now
post #3 of 35 Old 09-19-2011, 05:03 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
stick with 3"
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #4 of 35 Old 09-19-2011, 05:06 PM Thread Starter
1993redjeepyj
okay? is that an opinion or an answer?
like i said im looking at a the rustys off-road lift if i cant go more then 3 inchs
i would like to do a 3 inch with a 1 inch spacer if it is possible
so i ask again, any suggestions?
thanks,
steve
post #5 of 35 Old 09-19-2011, 05:07 PM Thread Starter
1993redjeepyj
5.9 andy,
thank you for an answer to the question.
now what is the reason for sticking with 3 inch? i wouldnt be able to go with a 3 inch kit and a 1 inch spacer?
because of the adjustments and length of the arms correct?
post #6 of 35 Old 09-19-2011, 05:26 PM Thread Starter
1993redjeepyj
Or do i just spend the extra few bucks and get the iron rock 4 inch http://www.ironrockoffroad.com/Merchant2/merchant.mvc?
post #7 of 35 Old 09-19-2011, 05:26 PM
Technohead
Originally Posted by 1993redjeepyj View Post
. . . because of the adjustments and length of the arms correct?
Yes. Its not so much the length of the arms (which should not change much no matter how much lift you have) as it is the ability to dial in pinion angles. Even 3" could be pushing it.
-Eric
Technohead is offline
post #8 of 35 Old 09-19-2011, 05:41 PM
Terokee
I am runniing the iron rock 3.5 kit with 33s and some trimming behind thr rear doors. Everything else is stock .
Terokee is offline
post #9 of 35 Old 09-19-2011, 05:47 PM Thread Starter
1993redjeepyj
okay, so in your opinion i should go with a kit with adjustable uppers and lowers? like the Iron rock 4 inch?
post #10 of 35 Old 09-19-2011, 06:48 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
what is your budget?
build thread:
5.9 ANDY is offline
post #11 of 35 Old 09-19-2011, 09:52 PM Thread Starter
1993redjeepyj
i sold my 93 YJ for 5000.
i gave myself 4000 to buy and build a ZJ
i bought the ZJ for 1000
maybe put 300 into it
so for a lift kit i have 700 800 for a lift.
it isnt going to be a "mudder" i dont need 7 inches of lift with huge amounts of flex.
it will be a daily driver in winter and will pull my trailer.
im happy with 3 inch lift. i would like 4.
i think i should just spend the extra bucks now to get a kit with arms so if so later on i can upgrade
post #12 of 35 Old 09-19-2011, 10:02 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i was going arounbd my local junk yard the other week, there was a dodge 1500 that had a rancho lift kit on it with some adjustable arms.
if i pulled them, yould you be interested in buyting them?
build thread:
5.9 ANDY is offline
post #13 of 35 Old 09-20-2011, 07:42 AM Thread Starter
1993redjeepyj
No no no.
i just want to know if it is worth investing the money into a kit with a long arm or adjustable arm set up.
i will go with the 4 inch rough country kit with adjustable arms
if its not worth it ill go with a 3 inch kit from fat bobs garage and be done with it for 200 bucks.
im just looking for opinions and suggestiions on is it worth the extra money
post #14 of 35 Old 09-20-2011, 08:30 AM
brady1604
i've got a 4" lift on my 96 zj. the control arm that came with the kit are about an inch longer than the stock arms. but the stock arms aren't made to handle the strain of the lift. i would spend the extra bucks and get the kit with the control arms. if you want a daily driver then you dont need all the adjustable crap. i bought the 4" kit from rusty's and it came with upper rear control arms that are adjustable, just to fix the drive shaft angle. spend the money, dont be cheap cause that's when you'll break stuff.
brady1604 is offline
post #15 of 35 Old 09-20-2011, 09:02 AM
speedbucket
actually if it is a dd (putting miles on it) it is more important to have adjustability to dial your pinion angles in for the extra miles your putting on it, if its a toy then your not putting the miles on it and extra wear from bad driveline angles
if you do the RC 4 inch you will still need to buy upper front adjustables and adjustable track bars
i have a mutt lift
-RC 3.5 with added spacers(fixed lowers, no uppers)
-then added upper adjustables (super flex rear uppers, Ironman fab upper fronts)
-Adjustable IRO front trackbar
-Adjustable IRO rear trackbar
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
A/C Question on a 1996 GC 5.2 LTD GS Audio ZJ Grand Cherokee Forum 8 09-26-2015 11:30 AM
1996 ZJ lift question EdZJ96 ZJ Grand Cherokee Forum 8 11-30-2010 04:57 PM
Help for lift GC ZJ 1996 aligator ZJ Grand Cherokee Forum 2 09-01-2009 12:21 PM
1996 V8 VC question.... mailforjon ZJ Grand Cherokee Forum 19 10-26-2005 12:22 AM
1996 ZJ speaker question? spankey ZJ Grand Cherokee Forum 1 10-19-2004 10:21 PM
