1996 ZJ eletrical problems. - JeepForum.com
View Poll Results: whats your favorite place to eat?
HOOTERS 7 46.67%
Outback 3 20.00%
Logans 1 6.67%
five guys 4 26.67%
Voters: 15. You may not vote on this poll
post #1 of 12 Old 08-09-2011, 10:26 AM Thread Starter
bcarter92
I have seen a bunch of people have the same problem for the coolant sensor bad and coolant level low message on the display screen. But the display screen doesnt want to stay on it like glitches and sometimes doesnt even come on. Another thing is sometimes when i crank up it idles at like 2000 rpms.Help
bcarter92 is offline
post #2 of 12 Old 08-09-2011, 10:53 AM
1stblack97ZJ
what the HELL is up with the poll at the top LMFAO that's funny.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #3 of 12 Old 08-09-2011, 10:58 AM
Midnightluckey
Lol I like the poll.
Well, the coolant level low thing is just a bad solder in the Vic. Coupled With the flickering, I'd say grab another Vic honestly. I paid what, 20 bucks for one? Or live without it. They're cheaply made and 15 years old. it's a common failure of the Vic.
If you're interested in saving it, there's a few write ups on where the bad solder is and how to fix it.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #4 of 12 Old 08-09-2011, 03:56 PM
LinBaba
I like Pie.....and....Boobies
and have strange intermittent electrical problems with my 96 5.2 LTD
LinBaba is offline
post #5 of 12 Old 08-09-2011, 04:24 PM
MeanGreenZJ
I like tacos and melons with a side order of rump roast.
All common problems that are easy to fix.
MeanGreenZJ is offline
post #6 of 12 Old 08-09-2011, 05:34 PM
1stblack97ZJ
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #7 of 12 Old 08-09-2011, 08:04 PM
goldshellback
My issue has been that I lose the gauge cluster while driving. Lights on it work but no gauges. My a/c will then start running warm air, my windows wont work. Here is what I dont understand at all. There are times that you can open the drivers door and they will start working again, you hit bumps in the road and will start working but most of the time lately it stays out. Tracking this down is becoming a heartache.
How easy a fix? Thisis killing me
goldshellback is offline
post #8 of 12 Old 08-09-2011, 08:16 PM
1stblack97ZJ
hooters is in the lead
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #9 of 12 Old 08-09-2011, 08:38 PM
MeanGreenZJ
I would check the drivers door wiring and connector. If that checks out I would check the BCM under the dash.
The "Body control modules" are built very poorly on the 96 models. I had one that would stop charging in cold winter weather and had to be restarted to get it to charge again, once the inside of the jeep heated up all was fine. It took me a year and a half you track down the problem since it only happened in the coldest weather. After checking all wiring and connectors that I though could be related, and after changing the PCM, alternator and ignition switch. I pulled out the BCM and cracked it open to find that one of the capacitors only had one leg soldered into the mainboard while the other leg just sat on the soldering joint. I heated up the joint and popped the other leg in there and needless to say drove the jeep another two winters without issue.
post #10 of 12 Old 08-12-2011, 09:10 AM
goldshellback
Roger that. I'll check that out this afternoon. Thanks for that heads-up.
post #11 of 12 Old 08-13-2011, 01:05 PM
goldshellback
FWIW, after getting under the steering column and disconnecting/reconnecting the BCM and checking all the wires....... AND...... cleaning the battery terminals and verifying all grounds were connected and good, my gauge cluster/AC/windows/locks/anti-theft 'SEEMS' to be corrected/fixed.
I didn't have to remove the dash and gauge cluster and check those connections and thank goodness I didn't have to pony-up for a BCM!
Hope that helps a few of ya. Using my google-fu and searching this site and reviewing ya'lls experience's and knowledge helped TREMENDOUSLY!
Thanx ya'll!
post #12 of 12 Old 08-13-2011, 07:51 PM
MeanGreenZJ
No problem the bill is in the mail.LOL
Need Help 1996 ZJ transmition problems moosedrul ZJ Grand Cherokee Forum 7 12-05-2009 11:59 AM
1996 grand cherokee problems hozer ZJ Grand Cherokee Forum 1 08-31-2009 09:46 PM
just got a 1996 gc laredo w/ problems Irvine860 ZJ Grand Cherokee Forum 0 07-07-2007 08:46 PM
eletrical or security problems leftys4js ZJ Grand Cherokee Forum 4 11-16-2006 08:01 PM
Electrical Problems in 1996 devile ZJ Grand Cherokee Forum 4 01-30-2005 07:29 PM
