1996 zj - JeepForum.com
post #1 of 6 Old 03-07-2011, 03:51 PM Thread Starter
diesel04
1996 zj
hey guys just pickedup a 96 limited with the 5.2. it starts and runs but dies within 5 seconds of running. start, stall, start stall.....continued. the asd relay clicks like crazy under the hood. also the flashing lights relay clicks too?.... i read somehwere else about the torx screws on the pcm, removed and nothing...... no engine light comes on at all. i am currenty boosting it when starting as battery eventually dies. i am starting to think it is the pcm. also, what about the throttle body sensor, would it cause this>?
diesel04 is offline
post #2 of 6 Old 03-07-2011, 04:54 PM
csouers
The alarm is going off (but no horn???) and is disabling the engine. Unlock it with the remote and key (in passenger door or hatch).
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #3 of 6 Old 03-08-2011, 04:42 AM
Pugulis
x2 your alarm is going off.
Pugulis is offline
post #4 of 6 Old 03-08-2011, 07:53 AM
speedbucket
the horn does not go off if the alarm is tripped by a battery reset.
everytime you try to start it you are resetting the battery
buy a battery
hook it up
turn off alarm
then start and you will be good to go
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #5 of 6 Old 03-10-2011, 05:10 PM Thread Starter
diesel04
ok i have a new battery in my other car so i will try, how do you turn alarm off? and is there anyway of disabling the alarm, this things got the auto start too. aftermarket of course.
diesel04 is offline
post #6 of 6 Old 03-10-2011, 06:05 PM
speedbucket
yes you can if you have a key fob you can disarm it
yes no key fob then turn the key in the rear latch and passenger side door lock
Help for lift GC ZJ 1996 aligator ZJ Grand Cherokee Forum 2 09-01-2009 11:21 AM
1996 ZJ hood? LouisZJ90 ZJ Grand Cherokee Forum 3 08-28-2009 12:00 AM
Does this go with a 1996 ZJ? whitejeep08 ZJ Grand Cherokee Forum 8 12-24-2006 01:06 PM
Should I buy it? 1996 GC 4.0L irochfo1 ZJ Grand Cherokee Forum 9 04-13-2004 07:07 PM
1996 v8 vs. I6 Zack2047 ZJ Grand Cherokee Forum 17 10-30-2003 07:32 AM
