1996 (UK) Grand Cherokee Dash Staying On After Ignition Turned Off! - JeepForum.com
post #1 of 2 Old 12-27-2007, 10:30 AM Thread Starter
paulcos66
Can anyone shed any light on the problem we are having with our 1996 Grand Cherokee Jeep (4.0 Petrol - Limited).
After a rainy weekend an error message appeared on the dashboard saying check gages and noticed alternator charge was 0. Following day the Jeep wouldn't start.
I had the battery checked out and found we needed a new one, which we subsequently did. However, we now have the problem that when the ignition is turned off and the key removed, the dashboard display is still illuminated and the internal heater / cooler fan is still running.
There does appear to be a clicking noise coming from one of the relays. Whether this is anything to do with the problem, we don't know?
Can anyone shed any light on the problem before having to take her to a dealer. We currently have to disconnect the battery when she's not being used to stop the battery being drained but once connected back up she starts fine.
paulcos66 is offline
post #2 of 2 Old 12-27-2007, 11:14 AM
gomes512
1994 ZJ
Don't have a Hayne's manual on hand at the moment but my bet is that there is a bad relay that is related to the ignition switch.
Try to hunt down the source of the clicking you mentioned. The relay should be labeled on the relay box cover.
gomes512 is offline
94 Grand Cherokee Laredo NIGHTMARE with staying running jason1977 ZJ Grand Cherokee Forum 19 08-24-2013 05:18 AM
1996 G Cherokee, AirControl Problem, No air out of dash vent lcg8657 ZJ Grand Cherokee Forum 0 02-21-2009 05:18 PM
Ignition Coil Wire location -1996 Grand Cherokee tullyamo ZJ Grand Cherokee Forum 2 11-25-2008 04:59 PM
1999 Grand cherokee 4.0 has trouble staying on after cold start eek142 ZJ Grand Cherokee Forum 4 02-10-2008 08:28 AM
Weird Noises from Dash after Ignition is Turned Off MyRedYJ ZJ Grand Cherokee Forum 6 07-25-2006 03:26 PM
