1996 Jeep Grand Cherokee Won't Start rigth away. - JeepForum.com
post #1 of 6 Old 12-05-2011, 01:08 PM Thread Starter
jskenyon
Dear All,
my 1996 Jeep Grand Cherokee isn't starting up right away. Battery turns on, and you can hear the fuel pump turn on. However, the engine doesn't start, just tries for a long time. sometimes the engine will turn over easier and other times it can take up to 10-15 minutes. Sounds a lot like this video http://www.youtube.com/all_comments?v=5NfqrTcnczM. Once the engine finally turns over, it runs well and doesn't stall.
Any suggestions?
Thanks.
jskenyon is offline
post #2 of 6 Old 12-05-2011, 01:11 PM Thread Starter
jskenyon
Should note that the starter & spark pug were replaced less than four years ago.
jskenyon is offline
post #3 of 6 Old 12-07-2011, 10:40 AM
zvanit03ru
I think you're misusing the phrase "turns over", which means that the engine is spinning, but not starting to run. Failure to "turn over" means that you get nothing but a click or bump, such as with a totally dead battery, or no sound at all, such as with a disconnected battery.
Assuming that your engine is indeed "turning over" when it fails to start, I would suspect one of two things first: a faulty automatic shutdown (ASD) relay, or a faulty crankshaft position sensor (CKP.)
To test the ASD relay, located in the electrical box under the hood, swap it with the horn or AC relay (whichever one is identical; both are on mine.)
I did not view the attached YouTube video because I'm at work and cannot do it on the terminal here.
zvanit03ru is offline
post #4 of 6 Old 12-09-2011, 11:24 PM
kevins79j10
1979 J-Series Truck
for what it's worth, i just took my 96 to the dealer for some PCM updates, and i think one of them was related to an issue similar to yours. might wanna take it there to have a look-see
kevins79j10 is offline
post #5 of 6 Old 12-10-2011, 12:30 AM
IdabJeepin
When you first role your key on before it starts the starter cranking, does your "CHECK ENGINE" light come on with all of your other check lights on your dash??? This thread is also for 4.0 IL6 motors also. Mine did the same thing you are talking about and I followed this thread and now I am running fine.
http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
93 ZJ 4.0 IL6
235/85/16 (32s)
2 inch BB
Aussie Locker up front Now I have a genuine 3-wheel drive 4x4!
Ramsay Winch on receiver so it can be used on front OR back of Jeep OR on my 4-wheeler OR to hang another bull elk up in a tree OR ???
Why do they call it common sense when it is so uncommon ?
Jeep Mods Are Like Eating Potato Chips.
Ya Can't Stop Having Just One.
IdabJeepin is offline
post #6 of 6 Old 12-10-2011, 09:25 AM
JS97ZJ
Originally Posted by jskenyon View Post
Dear All,
Any suggestions?
Thanks.
Have you tried using the zip ty fix to solve the problem?
This is for rhe 93-95 Jeeps.
JS97ZJ is offline
1996 Grand Cherokee code 12, won't start 242forme ZJ Grand Cherokee Forum 12 02-25-2015 06:53 PM
1996 Grand Cherokee won't start, has power, but starter doesn't engage justtalkin ZJ Grand Cherokee Forum 10 08-29-2011 06:21 PM
1996 Grand Cherokee won't start Winger67 ZJ Grand Cherokee Forum 3 06-10-2010 04:08 PM
1996 Jeep Grand Cherokee - Electrical JDavid ZJ Grand Cherokee Forum 1 11-28-2006 09:06 AM
1996 Grand Cherokee - Won't Start (Sometimes) muzicman82 ZJ Grand Cherokee Forum 4 01-02-2004 04:09 PM
