1996 Jeep Grand Cherokee Taillights fuse keeps popping - JeepForum.com
post #1 of 6 Old 01-16-2011, 12:08 PM Thread Starter
lj92694
The fuse for my taillights pops instantly when i turn them on. I tried replacing the headlight switch and no luck. Any suggestions or do i have to dig through my whole dash to find the problem?
lj92694 is offline
post #2 of 6 Old 01-16-2011, 12:35 PM
JS97ZJ
You should start by checking by the lamps themselves. Frayed wires at the sockets, pinched wires in an area where you or someone else may have done some work that may have caused a situation, where over time caused short.
I've also seen burnt out bulbs cause a shorted condition. The switch would no have been on my first to do list.
P.S.
JS97ZJ is offline
post #3 of 6 Old 01-16-2011, 01:15 PM
jnicewan
It would be almost impossible for the headlamp switch to cause a short thats blowing the tail lamp circuit fuse, I would start with what was mentioned in the above post. Also check all the marker lights/bulbs and sockets. If you have some trailer light wiring under the rear bumper, check that too.
Look for wires that are loose, corroded, piched/chaffed on something etc. Remove the lamp/lenses and unplug them or the bulbs and see if the short has gone away.
jnicewan is offline
post #4 of 6 Old 01-16-2011, 02:40 PM Thread Starter
lj92694
the reason i replaced the switch was because the dash will not light up either. Sorry i forgot to mention that. i think the fuse for the dash/taillights is the same.
lj92694 is offline
post #5 of 6 Old 05-03-2011, 01:53 PM
Jaxco
This problem sounds like mine.
No instrument panel or tail lamps - 7.5amp instrument panel fuse seems fine. All turn signals, brake lamps and other lamps work
Jaxco is offline
post #6 of 6 Old 01-07-2015, 09:44 AM
johnnyjeep123
John.. Issue Found
I read the Issue, That Everyone Had........ The Fuse Pops For the Tail Lights, Plus the Interior lights.......on any Jeep I guess That is a 1996... The Problem is Behind the Dash, where the 4x4 High, low, Part time connector is.... Blue/Red Wire Rubs on Sharp Edge....... Take apart the Glove boxs Assy to get to it...
johnnyjeep123 is offline
fuse , problem , switch , tail lights
How do I replace the grille of my 1996 Jeep Grand Cherokee? obinder26 ZJ Grand Cherokee Forum 3 01-25-2009 08:27 PM
1996 Jeep Grand Cherokee Limited Question mbg-jeep ZJ Grand Cherokee Forum 6 01-01-2009 12:41 PM
Jeep Grand Cherokee (1996) Starter question Bamf947 ZJ Grand Cherokee Forum 2 07-01-2007 05:58 PM
1996 Jeep Grand Cherokee - Electrical JDavid ZJ Grand Cherokee Forum 1 11-28-2006 08:06 AM
