1996 Jeep grand cherokee laredo (control arm torque specs) - JeepForum.com
post #1 of 15 Old 01-01-2013, 11:20 PM Thread Starter
Draven_Caine
As the title states I am looking for the torque specs for the front, rear, upper and lower control arms. (yes I am replacing all eight)
Also I was told I can change these pretty simply with the Jeep still on all four tires? Should I take the weight off the one tire that I am change the control arm on?
Thanks in advanced for any help.
Draven_Caine is offline
post #2 of 15 Old 01-01-2013, 11:28 PM
jetjr91
Suspension Arm Upper Nuts . . . . . . . . . . . . . . . . . . . . .75 Nm (55ft. lbs.) Suspension Arm Lower Axle Bracket Nut. . . . . . . . . . .115 Nm (85ft. lbs.
Google search.
Do one at a time
jetjr91 is offline
post #3 of 15 Old 01-01-2013, 11:31 PM
jetjr91
Suspension Arm Upper Nuts . . . . . . . . . . . . . . . . . . . . .75 Nm (55ft. lbs.) Suspension Arm Lower Nuts. . . . . . . . . . . . . . . . . . . .177 Nm (130 ft. lbs.)
For the rears^
jetjr91 is offline
post #4 of 15 Old 01-01-2013, 11:45 PM
KoreaZJ
1994 ZJ
Welcome to JF!
Front axle is easier with it dropped down, especially if you're changing the axle bushings.
Have everything down sitting normally before tightening so the bushings aren't torqued.
KoreaZJ is offline
post #5 of 15 Old 01-13-2013, 09:01 AM Thread Starter
Draven_Caine
Originally Posted by KoreaZJ View Post
Welcome to JF!
Ont he front upper control arms, the end connecting to the axle is a bracket that sits ont he axle bracket with a bushing in between the two brackets, what si this bushing called. I can't seem to find it anywhere.
post #6 of 15 Old 01-13-2013, 09:43 AM
OverlandZJ
Upper control arm bushing.
About $6 each at Rockauto.
http://www.rockauto.com/catalog/rafr...773656-1221578
OverlandZJ is offline
post #7 of 15 Old 01-13-2013, 09:44 AM
OverlandZJ
Your local parts store may have this in stock also.
post #8 of 15 Old 01-13-2013, 11:32 AM Thread Starter
Draven_Caine
Mine is a 1996 jeep but I don't think that will matter much. Alos are these bushing pressed in?
post #9 of 15 Old 01-13-2013, 11:36 AM
KJK
Originally Posted by Draven_Caine View Post
... Alos are these bushing pressed in?
Yes they are pressed into the arms except for the front axle uppers. They are pressed into the axle.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #10 of 15 Old 01-13-2013, 11:38 AM Thread Starter
Draven_Caine
Ok, now is there a assembly for the axle upper that has the bushing already pressed in, this was the reason I bought the full control arm to avoid the pressed in work.
I know sounds like a dumb question bt I have to avoid doing the pressed in part due to my tools, work area, ect.
post #11 of 15 Old 01-13-2013, 12:37 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
No, the bushing sleeve is cast into the pumpkin on the drivers side and the passenger is a welded on bracket.
Do not final torque the bolts till the full weight of the vehicle is on the tires.
ratmonkey is offline
post #12 of 15 Old 01-13-2013, 05:11 PM
KoreaZJ
1994 ZJ
Front upper axle bushings... something like this (pumpkin mount ratmonkey mentioned)...
Then...
Then all that's left is pressing the new bushings in...
KoreaZJ is offline
post #13 of 15 Old 01-31-2013, 08:54 AM Thread Starter
Draven_Caine
Ok all the control arms are on and in place. The rears are torqued down, now to the front. I had one question first ...
If I turn my wheel all the way one way the top of my tire leans out. For example if I turn my wheels all the way right, the top of my passanger-side wheel lean out. Is this fixed by the caster (think that is the name) washers? The washers on the lower front control arms when the control arm connects to the axle?
post #14 of 15 Old 02-03-2013, 04:21 PM Thread Starter
Draven_Caine
I just wanted to drop an update up for those that were helping me with this issue.
I have all the control arms on and the rear and 2 of the fronts are torqued down. Due to my tools right now I can get to some of the bolts so a buddy of mine is going to do it that works at a shop.
Also here is my write up of the Job http://www.keris-treasure-box.com/au...o/control-arms
The Jeep handles and drive like a dream again, thanks everyone for putting up with my dumb questions.
post #15 of 15 Old 08-17-2015, 08:03 PM
masalma
Thanks for this thread. Just finished replacing all rear control arms. To line up the lower had to use a ratchet strap around the axle and other end to frame. Lower control arm I just kept rocking it while under until it lined up. Sure could have used an extra hand to rock it.
Now waiting for my front control arms to show up in the mail. The 5.9 is happy it's getting new parts.
Thanks.
masalma is offline
