1996 Grand Cherkokee remote programming - JeepForum.com
post #1 of 4 Old 05-31-2003, 04:41 PM Thread Starter
jrenegade13
Can anyone tell me how to program the remote to a 96 Grand Cherokee?
jrenegade13 is offline
post #2 of 4 Old 05-31-2003, 10:56 PM
f14x4
remote for alarm or garage door?
(0IIIII0)
THERES ONLY ONE
f14x4 is offline
post #3 of 4 Old 05-31-2003, 11:01 PM
imnotu
imnotu's Avatar
try this
(1) Open the driverís door and leave it open during the programming process.
(2) Move the mechanical door lock lever on the driverís door to the LOCK position.
(3) Insert the ignition key and turn it to the RUN position. (Do not start the vehicle.)
(4) After turning the ignition key to the Run position aim the transmitter at the receiver and press the LOCK (right)button for 5 seconds. Once the receiver accepts the programming the door will unlock.
(5) If additional transmitters are to be used on the vehicle each must be programmed during the programming sequence. (Up to4 transmitters can be programmed to a vehicle) To program additional transmitters: Return the mechanical door lock lever on the driverís door to the LOCK position and aim the next transmitter at the receiver and
press the LOCK (right) button for 5 seconds. Again when the receiver accepts the programming the door will unlock.
Repeat step 5 until all transmitters have been programmed.
(6) When all transmitters have been programmed to the receiver, the ignition must be turned off and back on within 20 seconds after programming the last transmitter. When this is done, only the transmitters that were programmed to the vehicle during this procedure will operate the locks.
i can not take all the credit if this worked, i found this post when i looked for some infor on factory alarms a few days ago and Neil posted this here
http://www.jeepforum.com/forum/showt...threadid=10143
hope it helps
I6 w/ Selec-Trac, Plush Leather Seats (powered in front), JVC MP3 deck (STOLEN),
(Insurance messed up and gave me this instead),
, Remote Start, Optima Red Top, 180 Thermostat, Kolak Performance 2.5" exhaust components: (Car Sound high flow converter, Magnaflow large case muffler, mandrel bent tailpipe), 16x8 Rubicon Rims with 245/70 Bridgestone Dueler A/T Revo Tires, Rancho SS, Mopar Skids all around, Tow hooks front and back, Bilstein Heavy Duty Shocks and Clear Corners. [B]149/B], and still going stro... OK My transfer case can a small leak... damnit!.
imnotu is offline
post #4 of 4 Old 06-01-2003, 12:33 AM Thread Starter
jrenegade13
I have tried that, but that did not work for me. Those are the instructions on how to program a 98, not a 96. Thanks anyway.
Programming new key fob for 1996 Grand Cherokee llabnad ZJ Grand Cherokee Forum 5 11-28-2013 02:35 PM
WJ remote programming BradMB2004 ZJ Grand Cherokee Forum 2 07-16-2008 05:51 PM
1996 Keyless Programming CIoaked ZJ Grand Cherokee Forum 9 09-07-2006 05:38 PM
Programming Remote CaptainOats ZJ Grand Cherokee Forum 2 10-25-2005 10:26 AM
remote programming colt0380 ZJ Grand Cherokee Forum 1 03-02-2005 05:24 PM
