1996 g.c laredo 4.0 2wd - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1996 g.c laredo 4.0 2wd
Brand New! Quadratec LED Headlights!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 08-22-2014, 12:08 PM   #1
anthonys
1996 g.c laredo 4.0 2wd no spark
its throwing a p0320 code, l tried a new coil, played with wires and it still has no spark
can anyone help me, get some spark
pcm has been replaced
anthonys is offline   Reply With Quote
Unread 08-22-2014, 08:14 PM   #2
merc07
Defective Crankshaft Position Sensor
Faulty or corroded Crankshaft Position Sensor wiring or connections
that's where I would start
98 4.0 4" zone lift IRO double shear tb 31" nankang mudstars "rebuilt not bought"
MOPAR FOR LIFE
merc07 is offline   Reply With Quote
Unread 08-23-2014, 08:38 AM   #3
ZeeJay1997
the FSM for a 97 does not list p0320 as a valid code.
ZeeJay1997 is offline   Reply With Quote
Unread 08-23-2014, 09:17 AM   #4
JS97ZJ
Zee.....I checked my 97 manual and your right. The 98 manual shows it to be a crank sensor fault. Does the 96 throw 320 faults for the crank?
JS97ZJ is offline   Reply With Quote
Unread 08-23-2014, 12:08 PM   #5
ZeeJay1997
i'm not sure. i dont know why the codes would be differnt from 96 to 97. OP may have a 98 pcm in a 96 model? or actually has a 98?
