1995 zj w/ part-time 4x4 - JeepForum.com
post #1 of 10 Old 12-07-2009, 10:33 AM Thread Starter
fatboys95zj
I have a 1995 zj and it has the part-time 4x4 transfer case, my buddy has a 1996 ford explorer and he has the options of 2wd, 4 auto, and 4 lo. he came across a mod on the explorer forum which is called the brown wire mod. it turned the 4 auto into a 4 hi. any mod i can do to do this to make it run to a toggle like have in it 2wd and flip the toggle and its locked in 4 hi?
95 ZJ 2in BB 31 buckshots, lincoln locker in the rear.
"when in doubt, throttle out!"
fatboys95zj is offline
post #2 of 10 Old 12-07-2009, 10:37 AM
CatSplat
1994 ZJ
When you say "Part-time transfer case", does that mean you swapped in a 231 or 242?
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #3 of 10 Old 12-07-2009, 10:58 AM
Sextiva
I would think no as this system works off a viscous clutch like and awd car(as I understand it).
1996 GC
Sextiva is offline
post #4 of 10 Old 12-07-2009, 11:51 AM
Technohead
First of all, flipping a toggle to go from 2wd to 4wd is .
You said you had a "part-time case". In 95' ZJ's this could mean either a 231 (2wd, 4 hi, 4lo) or a 242 (2wd, 4ft, 4 hi, 4lo). I assume you DO NOT have the 249 since it does not have a part-time mode.
I know nothing about Explorers and can only assume that "4 auto" means there is some sort of differential inside the transfer case that does not split torque 50-50 front to rear. I further assume that by "4 hi" you mean the torque split is 50-50 front to rear. If so then it makes alot of sense why this brown wire mod is popular with the Explorer guys.
Now for the good news. No matter if you have the 231 or 242 t-case, the 4 hi mode locks front and rear together. And you already have a toggle to go from 2wd to 4 hi; its called the t-case lever.
-Eric
Technohead is offline
post #5 of 10 Old 12-07-2009, 12:18 PM Thread Starter
fatboys95zj
no my transfer case says 4 part-time neutral and 4 lo. i hate that its most of the time in 4 part i wish there was some way that i could change it where i could i have 2wd and 4 hi and 4 lo.
post #6 of 10 Old 12-07-2009, 12:36 PM
skunked_once
Since you have a 5.2 in your 95 you have the Quadra-Trac transfer case which came on all of the 5.2's. This transfer case uses a viscous coupler to engage the front wheels when the rear wheels start to slip. It is an all-wheel-drive and cannot be altered. The only way to get 2WD-4HI and 4LOW is to swap in a 231 or 242 transfer case. You can find all the information you need on that by doing a search.
skunked_once is offline
post #7 of 10 Old 12-07-2009, 01:08 PM
impuresoul2k3
I bet it doesn't say 4-part time, I bet its 4-full time
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #8 of 10 Old 12-07-2009, 02:14 PM
Technohead
Whats worse is that 93-95 249's did not lock front to rear even in 4 lo. The engineers that came up with that idea must have been pipe dreaming. If you want 2wd then you need to swap in a 231 or a 242. Matching up the input shaft lengths is a little tricky for 95's and earlier. Do your research before putting money on the table.
-Eric
post #9 of 10 Old 12-07-2009, 04:34 PM
1997ddzj
thats what im thinking
1997ddzj is offline
post #10 of 10 Old 12-07-2009, 04:47 PM
-Joe-
-Joe-'s Avatar
Answer is no..
The transfer cases used in these jeeps are mechanical not electrical.. So you can do all the wiring you want, you cant change the internal workings of the case in question.
I dont see why you would NEED a 2wd mode if you have a 4wd fulltime case. Maybe if you want to do burnouts or some silly stuff, you wont save on gas or any other nonsense..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
Part time and Full Time 4WD Difference Igorot_Jeeper ZJ Grand Cherokee Forum 12 06-09-2017 07:43 PM
Smoking Diffs? Part Time/Full Time? azcoyote ZJ Grand Cherokee Forum 30 04-01-2007 08:29 PM
part time light but no part time? jeep1987 ZJ Grand Cherokee Forum 5 12-05-2006 04:21 PM
GC Part-Time and Full-Time 4x4? What's the difference? rockon1202 ZJ Grand Cherokee Forum 14 03-04-2005 04:19 PM
Full time 4wd to part time conversion? yourNME13 ZJ Grand Cherokee Forum 6 04-20-2002 12:49 PM
