1995 ZJ Fog Light Switch Location? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1995 ZJ Fog Light Switch Location?
Tactical Recovery Equipment Soft Shackles!!!50% Off Sale at KrawlOff-Road.com50" LED CREE Light Bar Pair With Wiring Kit
Unread 08-13-2014, 02:06 PM   #1
EvansAustinT
I have checked everywhere, under fog lights, on top of the fog lights, headlights switch, around steering wheel and have found nothing. Where are they located?
EvansAustinT is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 02:44 PM   #2
kg6mov
Hears the voices
kg6mov's Avatar
On your 95 it's a setting on the rotary dial. Or it should be. Are you sure you have factory fogs?
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 08:20 PM   #3
Mickey_D
Yup, in order from left to right on the switch is:
Auto - lights come on as needed, when needed
Off - all lights off
Parking - parking lights only
Head - parking and headlamps on
Fog - Parking, head and fog (on low beam only) on. The fogs will go off as soon as the headlamps are switched to high beam (as it should).
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline   Reply With Quote Quick reply to this message
fog lights , jeep , zj
