1995 ZJ engine wiring harness - JeepForum.com
post #1 of 13 Old 01-14-2017, 10:02 PM Thread Starter
papitt
... I've looked on E-Bay found none & then I've googled motor & engine wiring harness . for 5.2 & for 1995.
... All I can get to come up has been later model 4.0L harness.
Rat have got onto my 95 XJ 5.2 V8 CHEWED on it. I'd like to see the cost for a replacement. After I get a new harness I'll most likely just cut the connectors I need & replace them onto my harness.
.. Or I'll ask can you buy the replacement pigtails for the injectors. I'm sure I can buy the AC PLUG.
papitt is offline
post #2 of 13 Old 01-15-2017, 03:45 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
http://www.ebay.com/itm/Genuine-Wiri...BYNH6c&vxp=mtr
Assuming a 95 has the same Siemens injector as a later model these should work, I'm not sure.
A less expensive option would be these.
http://www.wellsve.com/parts/index.p...54&PART_NO=414
http://www.wellsve.com/parts/index.p...28&PART_NO=715
The first wells link has one with a release, the second without a release.
Originally Posted by HighLonesome
coralman is offline
post #3 of 13 Old 01-15-2017, 04:41 PM
SAR-Swimmer
Lots of engine harnesses for 95 GC on car-part.com, go there, type in your location, and it will spit-out used parts near you.
SAR-Swimmer is offline
post #4 of 13 Old 01-15-2017, 05:01 PM Thread Starter
papitt
ok thanks That what I'm looking for I believe..
papitt is offline
post #5 of 13 Old 01-16-2017, 11:30 AM
Uniblurb
Uniblurb's Avatar
Dam rats, rodents and even some birds!
Probably 8-10 years ago I had a Carolina Wren make a dried moss nest on my intake right next to the header. Didn't know it and was driving down the road when the nest caught fire! My 96 cylinders were missing with smoke bellowing out from under the hood. Luckily when I pulled over and popped the hood the fire was out but it fried half my fuel injector harness.
I was going to just solder on new injector connectors but the dealer said that wouldn't work since it would change the wiring resistance. More power to them if my insurance wanted to pay for installing a whole new injector harness for $1,200 which they did with no deductible.
Personally I think the dealer was full of bull! Moral of the story is if you install just the injector connectors I'd solder them on, rather than using pinch wire splice connectors, and don't see how this could change the wire resistance. Even better if you find a whole new/used harness and good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #6 of 13 Old 01-16-2017, 01:15 PM
coralman
coralman's Avatar
The amount is tiny Uni if done properly. I would feel safe just using crimps if of the mopar variety. I was looking at my injector wiring when I had the engine out, and the runs protected by the plastics chase had pretty much fused the insulation together from heat and age, which is what I expect pappit will find. Wouid be a good slack time project to duplicate a harness, but the key word is slack.
coralman is offline
post #7 of 13 Old 01-16-2017, 01:44 PM
ZeeJay1997
That's an accurate deduction... definitely.
ZeeJay1997 is offline
post #8 of 13 Old 01-16-2017, 02:15 PM
zjosh93
Agree with above that the "change the injector resistance" line was ten pounds of crap in a five pound sack. Copper wire is on the order of 0.004 ohms per foot, the injectors are around 12 ohms. You can add a lot of wire before you'd have an issue. Assuming your wire splices are good that is. I'm working on a Megasquirt setup for my turbo car and injector wiring resistance isn't a concern.
RockAuto carries pigtails for just about everything on the engine harness.
I do have a spare 4.0 harness in my garage though so I can keep using factory connectors. Just unpin the broken stock one and snap pins into junkyard socket.
zjosh93 is offline
post #9 of 13 Old 01-17-2017, 06:39 AM Thread Starter
papitt
OK I stopped by NAPA & GOT 1 INJECTOR PIG TAIL . I pushed it onto my injector & it locked into place . Then I cut off the old connector . THE OLD ONE HAD A gREEN WIRE & a Gray wire . The NAPA one had 2 Black wire does it matter which wire are soldiered together. I'm thinking it doesn't matter . I was figuring on making them the same length.
papitt is offline
post #10 of 13 Old 01-17-2017, 06:54 AM
coralman
coralman's Avatar
It shouldn't I would think. But if you wanted to match them you can look for the curved side of the connector
that goes against the injector. Match the curved side for curved side and hook up the wires accordingly.
coralman is offline
post #11 of 13 Old 01-17-2017, 07:15 AM
zjosh93
The only thing in the injector is a simple coil. There are no diodes or other circuitry so polarity doesn't really matter. Bosch injectors (at least some) have one pin marked with a "+" sign. Net lore has it that they did it just to cut down on the number of support calls asking about polarity.
zjosh93 is offline
post #12 of 13 Old 01-17-2017, 07:43 PM Thread Starter
papitt
Yes Corl I found that curve & that's how I'm planing to do mine . It rained & was cold in Texas today . & I was feeling about 1/2 sick . So I'll get on it in a day or 2.
... Thanks guys.
... Also I'll though in here are the 6cyl harness pigtails the same as the V8's.
I just remembered that I change 3 4.0 a couple of years ago . & Seems like I had some left over harness.
papitt is offline
post #13 of 13 Old 01-18-2017, 08:53 PM Thread Starter
papitt
So I got a mechanic buddy to come by this evening & soldier on my pig tail... he soldier every day & I do 5 times a year. So after hearing all the stories I said to self. Let a pro do it. So it cranks & ran fine when done.
.. I'll move onto the next step of getting it on the road.
papitt is offline
