1995 ZJ blower motor not working - JeepForum.com
post #1 of 8 Old 05-10-2012, 07:37 PM Thread Starter
cody024
hi, just got my 95 zj limited today with the 5.2 engine in it. first thing i noticed was the blower motor wasn't working. what are the first things i should look at to fix this? any help at all would be appreciated. thanks.
cody024 is offline
post #2 of 8 Old 05-26-2012, 10:00 AM Thread Starter
cody024
Bump
cody024 is offline
post #3 of 8 Old 05-26-2012, 10:19 AM
JasonStebbins
The blower motor is the large black "box" under the passenger dash. It's a very easy fix. I can honestly say that was one of the first repairs I ever did on my own
Could also be the climate control unit itself, but that wasn't the case for me.
Poop
JasonStebbins is offline
post #4 of 8 Old 05-26-2012, 12:13 PM
Oldfrog
2007 WK
Mine did the same thing on my 97 4.0.
It was a loose connection on the switch. I removed the dash pieces, then the switch module piece....pressed on the back of each switch and it started working. ( after I had already removed the blower motor....duh !)
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #5 of 8 Old 05-26-2012, 03:06 PM
KoreaZJ
1994 ZJ
Does it work on HI speed only? If so, perhaps bad blower motor resistor (non-ATC), bad blower motor power module (ATC).
KoreaZJ is offline
post #6 of 8 Old 06-03-2012, 09:51 AM Thread Starter
cody024
Thanks guys. I'll be taking a look at it a but later.
cody024 is offline
post #7 of 8 Old 10-11-2012, 10:35 PM
NSS54358
How do I get the two screws out that hold the power module in place. One came out pretty easy although very hard to see and the one closets to the engine compartment I can not see at all ( I can only feel it). Its this second screw that I can get out....... Help!
NSS54358 is offline
post #8 of 8 Old 10-12-2012, 04:03 AM
zachjf
I used a mirror, small led flashlight, gorilla tape and a screwdriver bit holder and short extension on a 1/4" ratchet. Position the mirror so you can see the screw, gorilla tape the mirror to the underside of the dash to light up the area (aim the beam at the mirror) then use the ratchet and bit holder to get the screw out.
Needs parts?
PM
or
zachjf is offline
blower motor , zj
Blower motor not working jtarchala ZJ Grand Cherokee Forum 8 05-08-2015 11:42 PM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 03:33 PM
Blower Motor Not Working after AC drain was blocked speedbird1229 ZJ Grand Cherokee Forum 0 08-19-2008 02:17 AM
Signal lights, temp setting, blower motor all stopped working?? reedt_fc ZJ Grand Cherokee Forum 0 10-19-2006 01:37 PM
Blower Motor Stopped Working sharkjgc ZJ Grand Cherokee Forum 7 10-19-2004 05:29 PM
