1995 Laredo Weird "bucking" issues while driving - JeepForum.com
post #1 of 4 Old 08-06-2006, 04:17 AM Thread Starter
jrsquared
Hey,
I have a 1995 Laredo 4x4 sitting at the curb that has weird "bucking" type issues totally randomly while driving, sometimes it will happen, sometimes it won't. I don't really know how to explain it except as a bucking, jerking feeling. When it starts to happen, if I pull over, and rev the engine, it will sputter/buck/jerk as well. It will also stall sometimes at red lights (its an automatic). I don't know if these are all related or are completely different. Any help would be appreciated if anyone even knows what I'm talking about!
Thanks!
jrsquared is offline
post #2 of 4 Old 08-06-2006, 05:00 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Thatís a little unusual. My two guess are: fuel pump or output speed sensor.
Pull the codes
Extracting Fault Codes:
Turn the ignition switch ON, OFF, ON, OFF, ON and observe the CHECK ENGINE LIGHT. The CHECK ENGINE LIGHT should begin to flash a series of codes. The flashes will be separated by short and long pauses. The long pauses separate the "ones" and "tens" positions, and each code from the next. A code 55 will be displayed at the end of the test.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 4 Old 08-06-2006, 04:58 PM Thread Starter
jrsquared
I tried checking the codes, no codes... I want to sell it but I want to know if it would be worth it to fix it first. But if the problem is too hard to diagnose, I don't want to spend money replacing parts that arent the issue...
post #4 of 4 Old 07-12-2011, 07:20 AM
fishjeep1
this is the reply that I got, worked great hope it works for you
"That would most likely be your upstream 02 sensor (closest to the engine)
Unplug it for a few days . You will get a CEL , but , the symptoms should disappear and run fine . Replace sensor ASAP if this is the case . CEL will disappear after the sensor is reconnected ."
fishjeep1 is offline
"Unintended acceleration" 2005 Jeep Grand Cherokee Laredo mknight WK Grand Cherokee & XK Commander Forum 11 02-23-2010 01:43 PM
buzzing or weird sound when I shift the gear in " R " position - 3.0 crd XH segona WK Grand Cherokee & XK Commander Forum 15 12-02-2009 06:06 PM
"Relay Center" 1995 Grand Cherokee Phototaxis ZJ Grand Cherokee Forum 1 04-22-2008 08:48 AM
1995 zj bucking when turning spikeystrip ZJ Grand Cherokee Forum 5 03-22-2008 05:38 AM
burning "smell" issue and "gas pedal vibration" issue in 07 gc laredo beepbeep13 WK Grand Cherokee & XK Commander Forum 4 01-08-2007 06:06 PM
