1995 Jeep Grand Cherokee Limited i6 4.0 infamous stalling problem - Page 3 - JeepForum.com
post #31 of 49 Old 03-31-2011, 05:12 PM
awhyms
1997 Grand Cherokee Stalling Too...
Just wondering if anyone has had a problem with their Jeep like this:
Wife drove to AZ and Jeep wouldn't start. Took it to a mechanic who brought up a bunch of codes (catalytic converter, misfire, etc).
Changed plugs & spark plug wires and changed the catalytic converter along with fuel sensors & PCV valves when she got back to California.
Starting stalling 2 weeks later from time to time when she stopped at red lights. Check engine light comes on and codes say several misfires are occurring.
One mechanic says it may be the wire harness on top of the engine... Huh????
Now it seems to be stalling every other day...
Been spending lots on this vehicle.
Love this Jeep and could use a bit of advice to keep it from the junk pile.
Thanks!
awhyms is offline
post #32 of 49 Old 04-01-2011, 06:24 PM Thread Starter
sirwilliam706
i would look into the crankshaft and camshaft position sensor, coil or pickup inside dis.
sirwilliam706 is offline
post #33 of 49 Old 04-01-2011, 06:26 PM Thread Starter
sirwilliam706
post #34 of 49 Old 04-01-2011, 07:45 PM
ZeeJay1997
Thanks!
If you are getting consistent codes for misfiring cylinders you could have a fuel delivery problem. It may be that the fuel pump voltage is low or a weak charging system. Does the battery gauge drop when it idles?
ZeeJay1997 is offline
post #35 of 49 Old 04-02-2011, 02:13 AM
awhyms
The crankshaft sensor is one of a few items my mechanic is going to check on Monday....
Thanks!
awhyms is offline
post #36 of 49 Old 04-02-2011, 02:22 AM
awhyms
Thanks for the link... Very informative!
awhyms is offline
post #37 of 49 Old 04-02-2011, 02:25 AM
awhyms
ZeeJay,
The battery doesn't drop, but we had the fuel pump changed a couple of years ago.
Now that I think about it, the same problem started a few weeks later...
How does the mechanic check the fuel pump voltage?
awhyms is offline
post #38 of 49 Old 04-02-2011, 02:38 AM
MegaAlan
1990 XJ Cherokee
I fixed mine. Two days after installing new pump, started again. Dropped my tank, pulled out pump and found filter on pump clogged. Looked in tank and was like a mud pool. Cleaned tank out, filter... Problem solved... After spending $$$$ on everything else. Hope yours is this simple. I figured it out because it stalled worse when 1/4 or lower on fuel. Hope this helps.
90 XJ (Under Construction) Elec fan switch to dash. Overheating issue solved!
06 Dodge Megacab Cummins Diesel: 37X13.5 Mickey MTZ's/ 6" Superlift/ 6" dia. chrome miter smoke stacks.
MegaAlan is offline
post #39 of 49 Old 04-04-2011, 05:30 PM
awhyms
Thanks, MegaAlan... Just heard from my mechanic that he will have to replace
the fuel pump & do an injector test to make sure everything is working smoothly.
Hope this makes the wife happy!!!
awhyms is offline
post #40 of 49 Old 04-09-2011, 07:42 PM
jjbassman
I have been having the same problem as of late. Jumped on the interstate and she died. Found a weak spark for replaced the coil. Ran GREAT! A few miles down the interstate and pealed off and she started to act up again. Let her sit for a few minutes, then ran great through town. Even this AM, it ran great on the way to work, through town. Jumped on the interstate and she acted up again. Let sit, then drove through town, again no problem. So now looking at the fuel delivery. Any recommendations? I have a strong feeling its the fuel pump. Your thoughts?
jjbassman is offline
post #41 of 49 Old 04-11-2011, 10:10 PM
MegaAlan
1990 XJ Cherokee
It's possible. Does it only do it after it reaches operating temp, though?
MegaAlan is offline
post #42 of 49 Old 04-12-2011, 07:01 AM
jjbassman
Not necesarily operating temp. If i leave work and jump directly on the interstate I can get about 2-3 miles and it will act up. I can drive in town all day with no problem.
post #43 of 49 Old 04-12-2011, 11:50 AM
awhyms
Seems To Be A "Never-Ending Story" With Jeeps...
JJbassman,
I think it's a good idea to check the fuel delivery and electrical problems...
Days after changing the fuel pump my wife started having shut down & non-starting problems...
My mechanic found a loose connection at the brain and the computer itself is bad...
He's rechecked everything else including the coil and this is one of the last things to do...
Hopefully this does it!
awhyms is offline
post #44 of 49 Old 04-12-2011, 09:54 PM
MegaAlan
1990 XJ Cherokee
If you can drive all day in town, a fuel pump is doubtful.
[QUOTE=awhyms;11353308]JJbassman,
Hopefully this does it! [/QUOTE)
I agree that it could be electrical. You should have it scanned for codes and start from there.
MegaAlan is offline
post #45 of 49 Old 04-13-2011, 06:07 AM
jjbassman
I have priced used brains and they are around $50, but buyer beware. Another thing i checked last night was the fuel pressure at the fuel rail when running is at 50PSI, which IF i remember right, is where it should be. I also want to check this when it stalls out again. I do recall the first time it died, the fuel flow spitting out of the rail was pretty week.
From reading other posts, it seems that eventualy the brain is replaced and problem goes away, after everything else is replaced too. I keep coming back to the fuel delivery though, when driving through town, fuel isn't demanded as much as at a constant speed, like on the interstate. But, ultimately, everything runs through the brain.
Infamous stalling problem identified, temporary cure 1997 grand Cherokee lestercity12 ZJ Grand Cherokee Forum 887 01-26-2017 09:24 AM
1995 Jeep Grand Cherokee Limited 4x4 Stalling/Rough Idle HELP!!! Keith1975 ZJ Grand Cherokee Forum 22 08-05-2012 08:41 PM
1995 Jeep Grand Cherokee Limited 2.25 BB and BFG'S Jakeb2k4 ZJ Grand Cherokee Forum 13 01-07-2010 11:15 PM
My 1995 Jeep Grand Cherokee Limited Jakeb2k4 ZJ Grand Cherokee Forum 2 06-20-2008 05:53 PM
1995 Grand Cherokee Laredo Missing and Stalling angelmom ZJ Grand Cherokee Forum 0 09-06-2004 07:04 PM
