1995 Grand Cherokee no spart, no fuel, won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1995 Grand Cherokee no spart, no fuel, won't start
Poison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiBrakeline Closeout Deal! Kevlar Lined Stainless Steel Brai
Unread 11-17-2010, 09:29 AM   #1
kelseymonster
I have a 1995 Grand Cherokee Limited. 6cyl that won't always start. When you turn the key, the starter turns but won't start. I replaced the cranshaft pos sensor, the camshaft pos sensor, cap, button, wires, plugs, and coil.Nothing worked.
After about 30 mins to and hour with the key in the "ON" position, the fuel pump relay, auto shutdown relay, and fuel pump itself start to click rapidly. And the "security" light will be on. After about a minute, the clicking stops, the check engine light comes on and off, security light goes off, and I can start. It gets much worse in cold weather. Do you guys have any ideas?
kelseymonster is offline   Reply With Quote Quick reply to this message
Unread 11-19-2010, 02:29 PM   #2
j_alleyct_317
1994 ZJ
Sounds like you have the same problems as us sir. To the T. . . . Here is where we are at so far:
Click Here: 94 ZJ Crank But No Start
94 JGC Limited 4.0 42RE Quadra-trac, all original with 230K miles. 235/75-15 all-terrains and a snow bear plow for the winter.
This is my first Jeep and I love it, it'l be even better when I fix all the little qwerks.
j_alleyct_317 is offline   Reply With Quote Quick reply to this message
Unread 11-19-2010, 03:24 PM   #3
-Joe-
Sounds like bad caps in the computer.
It causes a delayed fuel system engagement type scenario.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote Quick reply to this message
Unread 11-22-2010, 10:46 AM   #4
kelseymonster
ok, guys, thank so much. I replaced the PCM over the weekend and it started right up!
no spark
