1995 Grand Cherokee no spart, no fuel, won't start - JeepForum.com
post #1 of 4 Old 11-17-2010, 09:29 AM Thread Starter
kelseymonster
I have a 1995 Grand Cherokee Limited. 6cyl that won't always start. When you turn the key, the starter turns but won't start. I replaced the cranshaft pos sensor, the camshaft pos sensor, cap, button, wires, plugs, and coil.Nothing worked.
After about 30 mins to and hour with the key in the "ON" position, the fuel pump relay, auto shutdown relay, and fuel pump itself start to click rapidly. And the "security" light will be on. After about a minute, the clicking stops, the check engine light comes on and off, security light goes off, and I can start. It gets much worse in cold weather. Do you guys have any ideas?
kelseymonster is offline
post #2 of 4 Old 11-19-2010, 02:29 PM
j_alleyct_317
1994 ZJ
Sounds like you have the same problems as us sir. To the T. . . . Here is where we are at so far:
Click Here: 94 ZJ Crank But No Start
94 JGC Limited 4.0 42RE Quadra-trac, all original with 230K miles. 235/75-15 all-terrains and a snow bear plow for the winter.
This is my first Jeep and I love it, it'l be even better when I fix all the little qwerks.
j_alleyct_317 is offline
post #3 of 4 Old 11-19-2010, 03:24 PM
-Joe-
-Joe-'s Avatar
Sounds like bad caps in the computer.
It causes a delayed fuel system engagement type scenario.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #4 of 4 Old 11-22-2010, 10:46 AM Thread Starter
kelseymonster
ok, guys, thank so much. I replaced the PCM over the weekend and it started right up!
no spark
help needed! 1995 grand cherokee 5.2 wont start, Stranded!!!!! jpclinging ZJ Grand Cherokee Forum 11 04-05-2010 09:34 PM
96 grand cherokee w/ good spark and fuel but won't start trh4989 ZJ Grand Cherokee Forum 7 02-14-2010 05:28 PM
1995 Grand Cherokee Hot No Start richpin06 ZJ Grand Cherokee Forum 6 09-21-2008 04:06 PM
1999 Grand Cherokee 4.0L won't start. No fuel to rail AND can't read computer --> fkacct ZJ Grand Cherokee Forum 9 07-05-2008 10:32 PM
Fuel shuts off after start...1995 Orvis katsjeep ZJ Grand Cherokee Forum 15 01-27-2008 10:36 AM
