1995 Grand Cherokee - Missfire problem - JeepForum.com
post #1 of 7 Old 08-02-2011, 10:14 PM Thread Starter
Orvisjeep
First off i want to say i have searched and searched the forums and cannot find a answer.
So i have a 1995 grand cherokee that has a major missfire issue. I just bought it with a new motor installed. 5.2L V8. The motor was installed 3 weeks ago, and ran fine at first. It has developed a missfire issue that i cannot figure out.
Things i have done are:
Ignition timing
new plugs
new wires
new ignition coil
new cap
new rotor
reset computer
Nothing has worked, and I am completly out of ideas. Does anyone have any more places to check?
Thanks.
Orvisjeep is offline
post #2 of 7 Old 08-02-2011, 11:55 PM
JS97ZJ
Possibly some junk got loose in the fuel lines and is restricting the injectors? Is the miss a steady miss or random? Run some injector cleaner. (?)
JS97ZJ is offline
post #3 of 7 Old 08-03-2011, 12:10 AM Thread Starter
Orvisjeep
It is steady at 1500rpm, and shakes the whole jeep at 2000rpms. Below and above those it runs fine.
post #4 of 7 Old 01-31-2013, 04:23 AM
Muaymendez
IM havng the same issue did you figure this out yet. This weekend will be tune up weekend, Caps rotor, pcm and IAC cleaning but I would hate to burn that cash and it nt solve the problem. And not to mentrion . I HATE DEAD END threads.
Muaymendez is offline
post #5 of 7 Old 01-31-2013, 10:28 AM
Snowfan2
Be sure your plug wires are run correctly. There is a TSB regarding routing.
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Snowfan2 is offline
post #6 of 7 Old 02-19-2013, 01:05 AM
Muaymendez
Just wanted to close this thread and let readers know my plugs and cap n rotor were toast. TB also needed a good cleaning.Everything good now
post #7 of 7 Old 03-14-2014, 08:46 PM
bobinAZ
hate to revive an old thread but, I was looking everywhere for that info.. the search function really does work!!! thanks
bobinAZ is offline
1995 Jeep Grand Cherokee Limited i6 4.0 infamous stalling problem sirwilliam706 ZJ Grand Cherokee Forum 48 05-10-2014 07:26 AM
1995 Grand Cherokee Security Problem Snipew4 ZJ Grand Cherokee Forum 5 05-28-2013 12:33 AM
5.7L in a 1995 grand cherokee?? AdamRice ZJ Grand Cherokee Forum 14 03-09-2007 11:29 AM
1995 Grand Cherokee 95PAGCLO ZJ Grand Cherokee Forum 15 06-13-2006 01:47 PM
1995 Ltd Grand Cherokee krypt68 ZJ Grand Cherokee Forum 12 12-16-2005 08:31 AM
