1995 Grand Cherokee Laredo Transmission - JeepForum.com
post #1 of 2 Old 05-12-2004, 10:41 AM Thread Starter
angelmom
I just found this web site which describes our problem to a "T". Can someone tell me what the TCM looks like and what will be involved in the repair? Where to find the part? Cost? Can hubby fix or does a dealer have to? Thanks!!
http://www.carsurvey.org/review_25063.html
Michelle and Ken
angelmom is offline
post #2 of 2 Old 05-12-2004, 12:04 PM
Meerkat
Michelle and Ken
If DH can change a light bulb, he can change the TCM. It is located on the driver's side under the dash, to the left of the steering column, mounted to the firewall. It is not very big, maybe 2 inches square and one inch thick.
Disconnect the cable from the negative terminal of the battery.
Unplug the electrical connector.
Remove the module mounting screws and/or nuts (should be in the engine compartment).
Remove the module from the cowl panel.
Installation is the reverse of removal.
Check with NAPA for availability. If they carry it, then you can call Autozone or one of those guys (usually lower prices than NAPA).
HTH
BTW, great job troubleshooting your problem!
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
grand cherokee laredo 1995 color code green ve2whz ZJ Grand Cherokee Forum 3 12-10-2007 07:52 PM
1995 Grand Cherokee Laredo Missing and Stalling angelmom ZJ Grand Cherokee Forum 0 09-06-2004 07:04 PM
1995 Grand Cherokee Laredo Stalls in Reverse angelmom ZJ Grand Cherokee Forum 2 09-06-2004 09:39 AM
1995 Grand Cherokee Laredo Transmission angelmom ZJ Grand Cherokee Forum 2 05-20-2004 01:17 AM
1995 Grand Cherokee Laredo psimpson ZJ Grand Cherokee Forum 0 12-21-2001 01:23 PM
