1995 Grand Cherokee Laredo Differential. - JeepForum.com
post #1 of 20 Old 10-11-2011, 05:26 PM Thread Starter
rdamurphy
2004 KJ Liberty
I just bought a 1995 Jeep Cherokee Larado, it has the SelecTrac, and looks like the towing package. I had some rear end noise, and the mechanic at work said it probably just needed an oil change, and it did indeed quiet it down and fixed the problem.
But he said it didn't look like a Limited Slip differential, but he wasn't sure (I work at a trucking company, they usually work on really really big differentials. Ones that need cranes.)
How can I tell if it's a LS or not?
4.0L, and like I said, it has a tow hitch, that appears factory, since the bumper goes around it.
Thanks!
Robert (N00b)
rdamurphy is offline
post #2 of 20 Old 10-11-2011, 06:41 PM
Freestyle713
1994 ZJ
unless the PO installed one, you dont have one
Freestyle713 is offline
post #3 of 20 Old 10-11-2011, 09:37 PM Thread Starter
rdamurphy
2004 KJ Liberty
Thank you for your answer. Much appreciated!
post #4 of 20 Old 10-11-2011, 09:40 PM
PeriwinkleZJ
If you want jack both rear tires off the ground, and spin one tire. I Believe a limited slip rear end will spin both tires in the same direction, whereas an open differential will spin each tire in opposite directions. Some one verify this for me, as I only recall this from my step-dad(knowledgeable, but extremely old school), and reading somewhere.
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD:
PeriwinkleZJ is offline
post #5 of 20 Old 10-12-2011, 09:16 AM
tcar
Get a build sheet from a dealer or from
Jeep.com
You'll need your VIN.
It will tell you if you have a tow package, what diff, and fifty other things, etc.
Even U-Haul hitches fit inside the bumper. Does it say 'Mopar' on it?
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
post #6 of 20 Old 10-12-2011, 09:31 AM
PolkaPower
The limited slip only came in the 96+v8's with the D44a rear end as far as I know.
PolkaPower is offline
post #7 of 20 Old 10-12-2011, 09:43 AM
Freestyle713
1994 ZJ
i thought the only ones to come with limited slip was the niner and the early 93's?
post #8 of 20 Old 10-12-2011, 09:44 AM
dpshoup
2011 WK
http://www.compnine.com/vid.php
type in your vin and it will give you a build sheet
HT1 (SW/AW) USN RETIRED (HT-4946)
24 Jun 81-30 Jun 01
ASNT NDT Level III (VT, MT, PT)
02 WJ-4.7 My DD [04 WJ-4.0, 00 XJ-4.0 Gone]
03 WJ-4.0 Dau #1 DD
93 ZJ-5.2 Dau #2 DD
USN Jeep Club #153
dpshoup is offline
post #9 of 20 Old 10-12-2011, 09:53 AM
PolkaPower
I am pretty sure that all 96+ v8's with tow package had limited slip. It may have been an option for the 4.0. Jack up the back and spin the wheels.
post #10 of 20 Old 10-12-2011, 10:21 AM
moggie99
My 1996 4L with Dana 35 has an LSD - fitted from new by Jeep, according to the build sheet.
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2000 Nissan Patrol Y61
In the UK: 1969 MGC GT
moggie99 is offline
post #11 of 20 Old 10-12-2011, 10:34 AM
jmonty0523
What on the build sheet says limited slip? Mine says "DRMP Dana 35C/194MM Rear Axle" I'm assuming I have an open diff, correct?
jmonty0523 is offline
post #12 of 20 Old 10-12-2011, 11:42 AM
dpshoup
2011 WK
build sheet would have a line entry separate from the DRMP:
DSA-Anti-spin differential Rear Axle
24 Jun 81-30 Jun 01
03 WJ-4.0 Dau #1 DD
93 ZJ-5.2 Dau #2 DD
USN Jeep Club #153
dpshoup is offline
post #13 of 20 Old 10-12-2011, 12:17 PM
jmonty0523
I've been doing some more research, and I've seen comparisons of the open diff and the LSD unit. Am I correct in saying that the LSD unit is more cylindrical shaped and the open carrier is tapered on the end away from the ring gear?
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
post #14 of 20 Old 10-12-2011, 12:37 PM
rozco
weird.. because i thought all 5.2's come with a D44? i guess not.. but hey at least i have limited slip..
from my build sheet..
DJHS Dana M30/181MM Front Axle
DMEP 3.73 Axle Ratio
DSA Anti-Spin Differential Rear Axle
ELF 5.2L V8 MPI Engine
93' ZJ - 5.2L. 4.5" IRO lift. front long arms rear short adjustables. bilsteins. daystar bumps. 33" KM2's. rancho ss. rc quick discos. flowmaster 10 series.
rozco is offline
post #15 of 20 Old 10-12-2011, 12:49 PM
Freestyle713
1994 ZJ
96-98 v8's have a d44a, not d44
1995 Jeep Grand Cherokee Laredo. Need Help please. Tried everything. swelms ZJ Grand Cherokee Forum 59 11-11-2012 09:29 AM
1995 Grand Cherokee Laredo yetijeep ZJ Grand Cherokee Forum 4 06-01-2011 01:52 PM
1995 Grand Cherokee Laredo Transmission angelmom ZJ Grand Cherokee Forum 2 05-20-2004 12:17 AM
1995 Grand Cherokee Laredo Transmission angelmom ZJ Grand Cherokee Forum 1 05-12-2004 11:04 AM
1995 Grand Cherokee Laredo psimpson ZJ Grand Cherokee Forum 0 12-21-2001 12:23 PM
