1995 Grand Cherokee - JeepForum.com
post #1 of 16 Old 06-09-2006, 07:24 AM Thread Starter
95PAGCLO
1995 Grand Cherokee
I just purchased a 1995 Jeep Cherokee Laredo that is full time 4wd. It will not stay in 4hi when I can get it in 4hi. 4lo works ok, but it just won't shift at to 4hi. Can some please help...Thanks in advanced.
95PAGCLO is offline
post #2 of 16 Old 06-09-2006, 08:15 AM
lesgeaux
I am new to a Jeep GC also, just got a 96. I found that I have to have the transmission in nuetral to get the lever to shift to Hi or Lo.
lesgeaux is offline
post #3 of 16 Old 06-09-2006, 08:46 AM Thread Starter
95PAGCLO
Tried that...
I have tried that with no luck. No matter if you do in neutral or not it doesn't help it stay in 4hi, when it goes in 4hi.
95PAGCLO is offline
post #4 of 16 Old 06-09-2006, 09:49 AM
lesgeaux
There was a safety recall about the shifter (hi/lo) indent. I am not really sure what it means tho, but I checked and mine was done. Has your recall been done on that item?
lesgeaux is offline
post #5 of 16 Old 06-09-2006, 12:00 PM
-Joe-
-Joe-'s Avatar
What options do you have on your shift selector?
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #6 of 16 Old 06-09-2006, 12:19 PM Thread Starter
95PAGCLO
4hi and 4lo. Only two options? Do you nknow which system(tranfer case) I have?
95PAGCLO is offline
post #7 of 16 Old 06-09-2006, 12:21 PM Thread Starter
95PAGCLO
Is there any kind of vaccuum line that go to the transfer case that may assist with 4wheel drive selection?
95PAGCLO is offline
post #8 of 16 Old 06-09-2006, 01:02 PM
-Joe-
-Joe-'s Avatar
Sounds like you have the 249 transfer case.
You sure its in 4wd low? mabye the linkage is off.
- Joe -
-Joe- is offline
post #9 of 16 Old 06-09-2006, 01:04 PM
UFO
UFO's Avatar
A little confusion about your selector, you stated you only have 4HI and 4LO, but I believe you're confusing fulltime (aka FT) with 4HI, they are not the same thing. You have the NP249 (sometimes called NV, same thing.) Take a look at the Grand Cherokee FAQ (http://www.jeepforum.com/forum/showthread.php?t=150055) for more information.
You say you are stuck in 4lo, know that driving on a paved road in 4lo is not good for the transfer case.
You said it won't stay in 4hi, are you shifting from 4lo to neutral to 4hi, or do you quickly shift with one motion? Some jeeps like it one way, some like it another, play with it. Are you at a complete stand still or rolling slowly when you transfer? I learned that slow rollin around 1mph is perfect for mine, if I'm at a stand still when I try to slip into 4lo it likes to not connect and slip back into neutral.
Hope that helps!
Rig: 1995 JGC 5.2L V8 Limited 129K Installed: 4.25" (Rusty's 3" coils and 1.75" spacers, removed stock spacer) with 32x11.5R15 Pirelli "Scorpion A/T's" on Cragar "Soft 8's" || Rusty's Adj. Front UCAs and LCAs, Adj. Front Trackbar, Shocks and Steering Stab. || Kevin's Adj. Rear Trackbar || R.E.'s Extended Swaybar Links w/ conversion kit
UFO is offline
post #10 of 16 Old 06-09-2006, 02:29 PM Thread Starter
95PAGCLO
I am pretty sure its in 4wd lo , Trans is in 3rd go and engine is at about 5,000 rpm go in 25mph. I tried to adjust the linkage both way but I it didn't help.
95PAGCLO is offline
post #11 of 16 Old 06-09-2006, 02:33 PM Thread Starter
95PAGCLO
Hope that helps!
I know that driving the truck on paved roads in 4lo is not good, that why I am not driving it and trying to get help on the forum. When it does engage in 4wd hi as soon as drive it to the end of my block, the tranfer case goes back into neutral.
95PAGCLO is offline
post #12 of 16 Old 06-09-2006, 02:55 PM
-Joe-
-Joe-'s Avatar
Have you checked/changed the fluid in it?
- Joe -
-Joe- is offline
post #13 of 16 Old 06-09-2006, 10:29 PM
draxxuspainter8
im jsut gona throw this out there, but u should be moving about 5mph when u shift into 4hi, and make sure ur shifter is in N, and then go to 4lo to hi in one motion. Give it a good push.
1995 zj v8 5.2l
AEM Brute force
Pacesetter catback
sony xplods
sony headunit
draxxuspainter8 is offline
post #14 of 16 Old 06-10-2006, 02:28 PM Thread Starter
95PAGCLO
Do the Transmission and Transfer case use the same fluid? Dexton III?
95PAGCLO is offline
post #15 of 16 Old 06-10-2006, 06:58 PM
jeepdude06
with my 95 GC laredo, i have to throw it into either neutral or park to shift from all time to lo. i usually use park, and ive had good luck gettin outta some deep **** with lo
jeepdude06 is offline
1995 Grand Cherokee Hot No Start richpin06 ZJ Grand Cherokee Forum 6 09-21-2008 05:06 PM
1995 jeep grand cherokee ZJ 4x4jeepzj ZJ Grand Cherokee Forum 28 05-13-2008 12:20 PM
5.7L in a 1995 grand cherokee?? AdamRice ZJ Grand Cherokee Forum 14 03-09-2007 12:29 PM
1995 Ltd Grand Cherokee krypt68 ZJ Grand Cherokee Forum 12 12-16-2005 09:31 AM
1995 Grand Cherokee Laredo psimpson ZJ Grand Cherokee Forum 0 12-21-2001 01:23 PM
