1994 ZJ viscous coupler problem? - Page 2 - JeepForum.com
post #16 of 23 Old 10-12-2013, 07:41 AM
Timo_90xj
Timo_90xj's Avatar
Originally Posted by ZJfamilyfun View Post
Ummmm....im confused. Correct me if im wrong, but only the 96-98 249's have VC's. And the 93-96 have more like a clutch pack.
Nope.
All ZJs with the AWD case are 249s, all of them have a viscous coupler. There is a slight difference in the design of the system between the early- and late-model 249s though, '96-'98 being the better of the two.
***Under construction***
Timo_90xj is offline
post #17 of 23 Old 10-12-2013, 09:46 AM
PolkaPower
Ummmm....im confused. Correct me if im wrong, but only the 96-98 249's have VC's. And the 93-96 have more like a clutch pack. So if you are experiencing wheel hop/bind start with the tire and also check the u-joint/CV-joint on that side.
All 249's have a VC. I have never had binding or hopping from a CV joint. Probably because I noticed it was going bad way before that could happen. Just clicks and pops. All 249 equipped ZJ's had CV shafts.
PolkaPower is offline
post #18 of 23 Old 10-12-2013, 10:50 AM
tucsonzj
Half shafts, not drive shafts
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #19 of 23 Old 10-12-2013, 11:27 AM
PolkaPower
I was indeed talking about the axles. CV drive shafts weren't used until mid 95ish give or take.
post #20 of 23 Old 10-12-2013, 03:49 PM
tucsonzj
I know, I was just clarifying for other readers so we didn't confuse them anymore than usual lol.
tucsonzj is offline
post #21 of 23 Old 10-20-2013, 12:22 AM Thread Starter
bigcase007
Just to clarify the NP231 out of the Comanche should work for my swap?
bigcase007 is offline
post #22 of 23 Old 10-20-2013, 12:51 AM
JohnnyZJ
6 cyl yes. 4 cyl no.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #23 of 23 Old 10-20-2013, 01:03 AM Thread Starter
bigcase007
Ok thank you good to know
