1994 ZJ viscous coupler problem? - JeepForum.com
post #1 of 23 Old 10-10-2013, 11:38 PM Thread Starter
bigcase007
Ok recently purchased a 1994 Grand Cherokee with the V8 with the NP249 transfer case with 100K on it. Runs great aside when turning in parking lots, driveways etc. its the front right side seems to want to hop and sounds like it's the viscous coupler from everything I've read. But looking at the tires three tires are michelin 235/75R15, the front right tire is a 225/75R15 Goodyear with horrible cupping on it. Could the problem be just the tire size difference? Or as I fear the coupler is smoked?
bigcase007 is offline
post #2 of 23 Old 10-11-2013, 02:32 AM
Timo_90xj
Timo_90xj's Avatar
Yes, your problem is the different size tire, and most likely it has burned the VC. With the 249 you MUST have same size tires, and adjust the PSI so that the actual diameter is very close the same between front and rear.
***Under construction***
Timo_90xj is offline
post #3 of 23 Old 10-11-2013, 08:00 AM Thread Starter
bigcase007
That's what I figured, it seems to be intermittent but looks like I may be doing the TC swap when I can gather enough funds. Thanks for the input.
-Casey
post #4 of 23 Old 10-11-2013, 09:32 AM
Timo_90xj
Timo_90xj's Avatar
If the tire pulsing/ hopping bugs you a lot, you can unbolt the front DS until you get the VC replaced and you get same size tires.
post #5 of 23 Old 10-11-2013, 09:41 AM Thread Starter
bigcase007
Cool thank you, I think I might try that. Is it correct that I will need to use the E-brake when parked to keep from rolling?
post #6 of 23 Old 10-11-2013, 09:52 AM
PolkaPower
Be careful, on the early 93-95 249 cases, removing the front shaft can allow the truck to roll in park. Just make sure you are not on any inclines and you put the e brake on.
96+ it doesn't matter.
PolkaPower is online now
post #7 of 23 Old 10-11-2013, 09:56 AM
Timo_90xj
Timo_90xj's Avatar
Crap, how did I miss you've got a 1994. I somehow read '97.
Yeah, you cannot run the older '93-'95 models without the front DS (or you can, but it's not the best of ideas). My bad, sorry
post #8 of 23 Old 10-11-2013, 01:00 PM
dnuccio
and if you take out the front driveshaft on a early (93-95) 249, if the viscous coupler wasnt shot before, it will be after you take the driveshaft out and drive it.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 23 Old 10-11-2013, 02:47 PM
tucsonzj
haha if you do, make sure your ebrake works very well. but these axles do not like different size tires. hopefully it didnt damage anything inside the diff.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #10 of 23 Old 10-11-2013, 03:07 PM Thread Starter
bigcase007
What would be the first thing I should with very limited funds? Get two new front tires? Wait and save up for a NP231 and swap it? Replace the coupler?
Thanks
-Casey
post #11 of 23 Old 10-11-2013, 03:59 PM
PolkaPower
Either replace the coupler or case. A bad coupler will just start wearing out the new tires. Besides, if you replace the coupler you will need 5 new tires all the same. The 93-95 249 is more picky about that. If you have mismatched tires or tires with more tread than the others then it will wear out the VC faster. It's power is split 50/50. Later years like 96+ are like 10/90. Basically RWD until the tires slip.
post #12 of 23 Old 10-11-2013, 04:13 PM
jeepzj1998
If you get the 242, be certain you get the rear drive shaft as well. Also, don't forget the bezel that goes on the shifter. Probably wouldn't hurt to get the linkage from the donor too.
jeepzj1998 is offline
post #13 of 23 Old 10-11-2013, 06:53 PM
tucsonzj
If you have limited funds, if you can find a 242 at a jy and are handy that will be a 1 expense. You do risk damage to your front diff if you continue on 2 different sized tires. Depending on where you are you can find cheap used tires. Hell I have 4 sitting in my garage I can't find someone to buy.
tucsonzj is offline
post #14 of 23 Old 10-11-2013, 10:47 PM Thread Starter
bigcase007
Sorry to keep asking questions but I know the people on here are a immeasurable amount of help to a newbie like me.
I can get a NP231 out of a Comanche for $80 it seems like a good deal but what's your thoughts and from what I'm reading it should work? Is that right?
Thanks again everyone for your input.
-Casey
post #15 of 23 Old 10-12-2013, 06:52 AM
ZJfamilyfun
Ummmm....im confused. Correct me if im wrong, but only the 96-98 249's have VC's. And the 93-96 have more like a clutch pack. So if you are experiencing wheel hop/bind start with the tire and also check the u-joint/CV-joint on that side.
ZJfamilyfun is offline
