1994 ZJ - Tune Up Questions - JeepForum.com
post #1 of 9 Old 03-22-2006, 08:52 AM Thread Starter
Blacula
I've got a 1994 ZJ with 163K miles on it. This vehicle has never had a tune up, so was curious if you guys would recommend anything in addition to plugs, wires and O2 sensor?
I'm not much of a car guy, so please explain it in layman's terms. Thanks.
Blacula is offline
post #2 of 9 Old 03-22-2006, 09:04 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
What engine do you have (V8 or I6)? get a new Distributor cap & rotor. oil change. air filter. oil filter. Are you going to do this yourself?
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 9 Old 03-22-2006, 09:06 AM
Reloader77724
Reloader77724's Avatar
well I have a 5.2 97 model zj. What do you recommend?
Reloader77724 is offline
post #4 of 9 Old 03-22-2006, 09:07 AM Thread Starter
Blacula
It is the 4.0 V6. I've kept up with oil changes and air/oil filters at regular intervals. I'm planning to take it into a shop for the tune up, but want to be informed when I do.
The exhaust manifold and motor mounts were replaced a few years ago. I did have a new set of shocks installed less than a year ago, which seems to have cured my DW problem.
Blacula is offline
post #5 of 9 Old 03-22-2006, 09:13 AM
PlatinumZJ
PlatinumZJ's Avatar
FYI, It is a straight 6 or I6, not a V6. If you were gioing to DIY, the #1 plug is a B#$#$ to get at with the A/c and #6 isn't easy either.
Reloader77724, I hear the distributor cap is very difficult on the V8. I would do plugs, wires, distributor cap, rotor, air filter, oil filter, oil change.
Doug
Links:
for ZJ & WJ stuff,
post #6 of 9 Old 03-22-2006, 09:17 AM Thread Starter
Blacula
Gotcha. Thanks for the tips. I'd like to see this Jeep hit 250K at the very least. I've driven it all over the country from sea level to 8,000+ feet, and have quite a sentimental attachment to it.
Blacula is offline
post #7 of 9 Old 03-22-2006, 09:46 AM
ajmorell
ajmorell's Avatar
I didn't have any trouble at all getting either of them. The trick get getting the plug out of #1 is to get a long enough extension for your ratchet.
ajmorell is offline
post #8 of 9 Old 03-22-2006, 10:32 AM
sand zj
sand zj's Avatar
I have both engines in and I would say that they are both fairly easy to tune up. I have found however that my 4.0 like to go through plugs quicker than most.
I would go with Plugs (NKG), Wires (high perf 8mm), "HOT" coil (not neccesary, but you can gap plugs wider), Cap (any quality brand), Rotor (any), Air filter (I like the K&N cold air system), Change all fluids (eng, trans, t-case, axles, anti-freeze flush), New thermastat (cooler range will give more power but slightly worse fuel mileage), Check hoses (If spongy then replace both rad. and heater hoses, don't forget the short hoses by water pump), If belts are overly cracked then replace (belts- cracks running same direction as grooves are bad, less than 10 cracks per inch the other way is acceptable but I would replace), Check front end for any slop, ect.
This is how I treat my vehicles and I have het to be left stranded and I drive about 25,000/year on road and many hours off road as well.
DON'T FORGET- Replace muffler bearings with a high performance chromoly set and grease regularly as well as keeping headlight fluid full and clean!
Dan
If you don't get stuck, keep trying!
'96 ZJ 7" LA, 318, 231, 8.8 (welded), d30 (LockRight), 4.10's, 33x13.5x16 TSL's, no interior...
sand zj is offline
post #9 of 9 Old 03-22-2006, 11:35 AM
wh1te
wh1te's Avatar
1994 ZJ
Also its very important to make sure your flux capaciter will hold a charge.
'94 ZJ Laredo Factory Tow Package
NP 231 "Command-Trac" Dana 35c 3.73:1 30x9.50x15 BFG A/T
2" BB
custom: radiator support/ tow points
wh1te is offline
1994 ZJ lift questions prplhz96 ZJ Grand Cherokee Forum 28 06-05-2013 01:03 AM
Exhaust and tune-up questions ZJcrawler45 ZJ Grand Cherokee Forum 4 10-09-2008 07:21 PM
tune up questions. 1997zj ZJ Grand Cherokee Forum 6 12-08-2006 03:37 PM
Brake and tune up questions eagleknight ZJ Grand Cherokee Forum 2 09-23-2006 06:05 PM
3 questions, help! 1994 ZJ haywood ZJ Grand Cherokee Forum 3 01-10-2005 08:30 AM
