1994 - OBD1 or OBDII ?? - JeepForum.com
post #1 of 3 Old 10-24-2003, 01:01 AM Thread Starter
surfinmud
Hello,
I am working on a project with a 1994 Jeep Grand Cherokee. I was wondering if anyone could tell me where I could find software to pull trouble codes out of the ECU. Does anyone use Autotap or a similar program on their 1994 GC's?? Any help would be appreciated.
BTW, the end goal of this project is to have the jeep drive itself from LA to Las Vegas.
surfinmud is offline
post #2 of 3 Old 10-24-2003, 08:15 AM
imnotu
imnotu's Avatar
http://go.jeep-xj.info/HowtoECUcodes.htm
works the same on a ZJ
I6 w/ Selec-Trac, Plush Leather Seats (powered in front), JVC MP3 deck (STOLEN),
(Insurance messed up and gave me this instead),
, Remote Start, Optima Red Top, 180 Thermostat, Kolak Performance 2.5" exhaust components: (Car Sound high flow converter, Magnaflow large case muffler, mandrel bent tailpipe), 16x8 Rubicon Rims with 245/70 Bridgestone Dueler A/T Revo Tires, Rancho SS, Mopar Skids all around, Tow hooks front and back, Bilstein Heavy Duty Shocks and Clear Corners. [B]149/B], and still going stro... OK My transfer case can a small leak... damnit!.
imnotu is offline
post #3 of 3 Old 10-24-2003, 08:12 PM Thread Starter
surfinmud
thanks for the info. What we really need is some type of software program that displays the inputs to the ECU. (Coolant temp, intake air temp, speed, rpm, etc ) Some of the more sophisticated software also allows you to map the fuel/spark tables / fans on temp/ and a variety of other adjustments.
I know of software that exists for my camaro, and was wondering if there is a similar program for the jeep? Thank you!
OBD1 and OBD2 FDSJr ZJ Grand Cherokee Forum 30 06-05-2013 08:28 PM
OBD1 key on-key off technique? spikeystrip ZJ Grand Cherokee Forum 2 07-14-2009 01:29 PM
95 GC 5.2 can you test OBD1 spikeystrip ZJ Grand Cherokee Forum 1 07-09-2009 09:57 PM
Tuning Options for OBD1 V8 RebelW26GT ZJ Grand Cherokee Forum 6 09-12-2007 08:02 AM
Obdii Codes 12 And 55...need Help CATMAN2 ZJ Grand Cherokee Forum 3 05-23-2003 01:20 AM
